Kitchenaid Refrigerator Not Making Ice - Appliances - DIY Chatroom Home Improvement Forum
Old 11-16-2009, 10:23 PM   #1
Kitchenaid refrigerator not making ice
My icemaker will not make ice in a Kitchenaid Superba model #KSRS27QGWH01 refrigerator. The water dispenser stopped working a few months back. I did a continuity test on the solenoid valve and the water dispenser side did not ring out, but the icemaker side did. Next, I tested the voltage on the water dispenser connection and got 120V when the water dispenser switch was depressed, the voltage on the icemaker connection was 0V with the icemaker switch in the on (down) position. The water supply to the inlet side of the valve is in the on position with plenty of pressure. The icemaker line is not frozen.
Bartolo M is offline   Reply With Quote
Old 11-17-2009, 12:19 PM   #2
General Contractor
If no water is coming out of the ice maker side of the valve, then you probably need a new one. I think those valves just wear out, I saw one that did that once.
KennMacMoragh is offline   Reply With Quote
Old 11-18-2009, 08:33 AM   #3
Household Handyman
Rewards Points: 1,408
Come to my house and I will give you a half-dozen ice-maker water control valves that read good continuity, or "ring out", but did not work when removed from service. Most of these valves have internal parts that go bad, or get grit from the water supply in them. I carry rebuilt valves with me and offer them to customers-cheap. IF I change out a valve for a new one, I rebuild the old one-usually a good internal cleaning, and keep it IF it works on my test stand. This is a good time to find out how one of these valves work. IF your's does not work you have two options, replace it with a new one, OR- take your's apart to see how it works, and see if you can clean/repair the internal parts. Often the screen on the inlet side is clogged and needs cleaning. Good Luck, David
Thinking about making concrete pavers - a few questions Luis C. Building & Construction 16 06-10-2011 05:45 PM
Installing a KitchenAid (Whirlpool) Cooktop Dennis Slater Electrical 3 10-29-2009 12:21 PM
kitchenaid ice not making ice #ksrg22fkwh04 stevefastv6 Appliances 2 07-27-2009 06:53 PM
GE fridge (older model) motor(?) making a lot of noise as it runs, also leak! liileah Appliances 1 06-24-2008 11:32 AM
Making bear totum pole Keith of Ronin Landscaping & Lawn Care 2 03-27-2005 01:22 PM
