Kitchenaid Range Fusing? - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-15-2011, 05:52 PM   #16
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you use the supplied voltage, which is 240 volts.
there are two 120 vac legs
While you can read 120 volts to ground to either leg, reading leg to leg (which is what is powering the heating element) you will see 240 volts. That is all that matters.
it should come out somewhere around 9 amps.
Old 01-15-2011, 06:30 PM   #17
-While you can read 120 volts to ground to either leg, reading leg to leg (which is what is powering the heating element) you will see 240 volts. That is all that matters.
2400/240=10 amps ..give or take due to anomalies in rated element wattage and supply voltage.
Barring the use of a clamp-on ammeter (to see what the actual draw is), a good starting point may be a 10 amp fuse link for that 14 awg 120 vac wire at the electronic panel ?
Daler is offline   Reply With Quote
Old 01-15-2011, 07:04 PM   #18
nap
You talking to me?
nap's Avatar
I would go up a step. Ambient temp is likely to come into play.
Old 01-15-2011, 07:16 PM   #19
..ok. howabout using a thermal fuse as seems it's common use on certain brands of ranges.
Old 01-15-2011, 09:03 PM   #20
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
I have serious doubts as what you are seeing is actually a fuse more likely it is just a circuit trace
hardwareman is offline   Reply With Quote
Old 01-15-2011, 09:07 PM   #21
#1 HAWKEYE FAN
btw that board here would run you a little over $300.00
Old 01-16-2011, 12:02 PM   #22
So then, where how is this unit (see attached YKESC307 print) and it's pricey pc panel are protected?
Because the pc foil ruptured between the bake relay and it's output molex plug, it seems logical that that hunk of solder streaked foil was the fusible link
Old 01-16-2011, 02:58 PM   #23
#1 HAWKEYE FAN
ok, how exactly did that "link" protect your pcb?? seems very illogical that a fusible link to protect your pcb would be part of your pcb since if that link blows you must replace the pcb anyway.
most if not all ranges built now have NO protection of any kind, the only protection I've ever seen on a free standing range was a few high end Kitchen Aid models that had a fusible link in the wiring harness. Take it for what its worth.
Old 01-16-2011, 04:10 PM   #24
Another repair guy says it is common if not normal to replace the pc panel along with the bake element ..duh, that's a pretty expensive maintenance duo!
So what is alluded to here is that the pc board itself is the range secondary protection?
It's really hard to believe that Kitchenaid would not protect some of its prime electrics via a fused device (like all those old stoves, etc). And yes, there is a large fusible link at the mains block in the rear.
Even so I still think that hunk of pc foil was the weakest link and was protecting that circuit by the fact that it ruptured here (see attached -- sorry for the pq) :
Old 01-16-2011, 04:33 PM   #25
#1 HAWKEYE FAN
I've been doing this a very long time, I've probably replaced hundreds of pcbs on ranges and probably thousands of heating elements, on RARE occasions when the bake element burns out it can take the pcb with it but that is very very rare and it is not common practice to replace the pcb with the element unless they are trying real hard to rake you over the coals
Old 01-16-2011, 05:14 PM   #26
So what are we looking at here in the pic (besides my 'fix')? What are all those lines of solder for on the pc circuit foils? ..and why did it blow there instead of somewhere else, huh?
Old 01-16-2011, 06:43 PM   #27
#1 HAWKEYE FAN
its really hard to tell what I'm looking at there because of your fix but I can almost gaurantee it is not a fuse, a pix from the other side would be more telling
Old 01-16-2011, 08:43 PM   #28
Here are a couple more pics:
1) closeup of rear pc patch (pretty ugly solder job but best I could do under the circumstances -- mechanically ok though)
2) front side (4-wire molex connector for elements, on left) violet = outer broil, black=convection ring, blue=inner broil, red=bake(the one at issue)
Those wires seem awfully small guage to be carrying 20~30 amps ..?
..thanks for this help
Kitchenaid range fusing?-pc_board_rear.jpg   Kitchenaid range fusing?-pc_board_front.jpg
Old 01-16-2011, 10:12 PM   #29
nap
You talking to me?
nap's Avatar
should have used a solid wire.
can you locate that in your schematic? Either my eyes are real fuzzy or the image is and I am having trouble reading anything well enough to find where in the schematic your situation is.
Old 01-17-2011, 10:39 AM   #30
now repaired -- thanks
Drop in range versus self standing for narrow area sbrink Kitchen & Bath Remodeling 6 01-21-2011 10:17 AM
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 07:48 AM
Backdraft, Cold Air and Ice from Range Hood and Bath Fan Passion4Heels HVAC 13 08-19-2010 07:00 PM
Had a new electric range installed in my apartment - does this sound right? SAABturboDRIVR Electrical 15 01-02-2010 05:39 AM
Ignition Problem with KitchenAid Gas Range dataflux Appliances 4 11-08-2009 05:01 AM
