Kitchenaid Kuds01flss1 Dishwasher Leaking - Appliances - DIY Chatroom Home Improvement Forum
Old 07-08-2014, 01:13 PM   #1
Rewards Points: 206
kitchenaid kuds01flss1 dishwasher leaking
I noticed that the dishwasher was leaking from the left side a month ago and thought it was the seal, so I ordered a new one for 35 bucks and installed it. It seemed to work, but now it's leaking again. I looked closely and don't see a rubber seal or anywhere where it would leak. I stopped it mid-cycle and there was water in the base of the washer. I took the door panel off and noticed that I can see the pan that the water is in, from the front and it has water in it too. My question is, is the water supposed to make it's way into the front of the pan or when the door is closed should that seal it off. Also, it's odd that the water is only leaking on the left side. Has anyone had a similar problem?
joeg679 is offline   Reply With Quote
Old 07-08-2014, 11:07 PM   #2
Rewards Points: 142
Click on link below. It may help give you more suggestions/advice as to what the problem may be. View the parts testing and replacment videos if needed.
Hopefully thefixer will respond to your post.
dishwasher leaking
jmon is offline   Reply With Quote
New Maytag dishwasher leaking! Gabe9195 Appliances 19 06-19-2013 12:31 AM
Bosch Dishwasher leaking along bottom seal of door mtbdudex Appliances 14 10-13-2012 09:49 AM
Water leaking out left side vent(?) of Dishwasher Barkley Online Appliances 8 01-14-2011 01:42 PM
Leaking Dishwasher Clean-up teamcanada Plumbing 0 06-23-2010 03:16 AM
KitchenAid Dishwasher Malfunction Vanquished Yet Again! Leah Frances Appliances 3 04-10-2009 10:22 PM
