-   -   Kitchenaid icemaker just stopped working (http://www.diychatroom.com/f47/kitchenaid-icemaker-just-stopped-working-114983/)
ecarter312 08-23-2011 08:11 AM
I have a KitchenAid refrigerator thatís 5 years old and Iím having trouble with it not producing any ice. The refrigerator model number is (KSRL25FRST04). Itís the side by side model with the ice bucket on the door. The Model # of the ice maker is S-106626663. Iím not getting any water from the inlet tube into the ice tray to make ice. I do get water out of the ice water unit on the front of the freezer door. Someone mentioned I might have a bad water valve thatís not shutting off the water which may be freezing the inlet tube with ice due to dribbling water, but thatís not the case. The inlet tube is soft and is not iced up hard as mentioned. Also mentioned were the infrared sensor assemblies from side to side that may be bad. I checked the red LED light on side, when the door is opened thereís two blinks follow a delay and two blinks and again followed a delay every two blinks. When the flapper is in the closed position I get a solid red LED light. The plastic ice ejector blades are in constant (slow) rotation. I was wondering if thereís something I can fix on my own before I call in a repair service. The Model # of the ice maker is S-106626663.
hardwareman 08-23-2011 09:55 AM
your infrared sensors are ok. If your icemaker is cycling like you say, then you probably do have a bad valve. You will need to check the valve to see if it receiving voltage when the icemaker is in the fill position.
ecarter312 08-23-2011 10:11 AM
Thank you for the quick reply. Yes, that's what I was thinking too. I have a volt meter, but not sure how to check the voltage on the valve. Could you give me a brief tutorial?
hardwareman 08-23-2011 12:13 PM
your valve in the back will have 2 solenoids on it, 1 for ice 1 for water. Figure out which solenoid is for ice by checking the wiring diagram or following the water tubing up to the ice maker. Your ice maker sends voltage to the solenoid when the fingers are at approximately 12 O'Clock. Check for 120 volts at solenoid. When you are back there you should be able to hear and feel the solenoid engage.
ecarter312 08-23-2011 01:24 PM
Great! That's exactly what I needed.
Thanks again
ebsparrow 05-26-2012 02:42 PM
I have this same issue and when i check the voltage at the solenoid for the ice maker stays around 9 and when the fingers are up the voltage drops to zero for a couple of seconds then goes back to around 9. I also switched the solenoid for the door water to the ice maker line and when i press the water door switch the water would fill the ice maker.
