Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-19-2012, 06:58 PM   #1
KitchenAid Icemaker in door will not dispense
I have a KitchenAid side-by-side with the ice bucket and dispenser in the door. Model KSRS25CSMS02...The dispenser motor will not operate and dispense ice. Water comes though the door just fine. I was about to replace the motor, but I removed it and put the shaft back in a spun it. It rotated fine, not grinding, no lockup. Is it possible that somehow this motor is operable but is not getting power? How would I know? Or are these motors prone to failure after 3 years?
stuartmiller450 is offline   Reply With Quote
Old 05-19-2012, 08:34 PM   #2
http://www.acmehowto.com/howto/appli...agicemaker.php
Old 05-19-2012, 09:41 PM   #3
Thank you for the link -- it didn't mention my issue, but I appreciate it nonetheless. You never know when you'll need info
Old 05-21-2012, 01:11 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
pull the two wires going to the motor, hook up a voltmeter , hold the door switch closed and then try the dispenser. It could the the dispenser switch.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Kitchenaid icemaker just stopped working ecarter312 Appliances 5 05-26-2012 02:42 PM
KitchenAid icemaker hook up? Braided SS or Copper?? titan7 Appliances 1 05-25-2011 10:24 PM
Icemaker works but won't dispense jjr Appliances 3 07-06-2010 10:48 PM
Kitchenaid refrigerator not making ice Bartolo M Appliances 2 11-18-2009 09:33 AM
Kitchenaid icemaker jack14246 Appliances 1 12-18-2008 05:06 PM
