-   -   KitchenAid Icemaker in door will not dispense (http://www.diychatroom.com/f47/kitchenaid-icemaker-door-will-not-dispense-144277/)
stuartmiller450 05-19-2012 05:58 PM
I have a KitchenAid side-by-side with the ice bucket and dispenser in the door. Model KSRS25CSMS02...The dispenser motor will not operate and dispense ice. Water comes though the door just fine. I was about to replace the motor, but I removed it and put the shaft back in a spun it. It rotated fine, not grinding, no lockup. Is it possible that somehow this motor is operable but is not getting power? How would I know? Or are these motors prone to failure after 3 years?
joecaption 05-19-2012 07:34 PM
http://www.acmehowto.com/howto/appli...agicemaker.php
stuartmiller450 05-19-2012 08:41 PM
Thank you
Thank you for the link -- it didn't mention my issue, but I appreciate it nonetheless. You never know when you'll need info
hardwareman 05-21-2012 12:11 PM
pull the two wires going to the motor, hook up a voltmeter , hold the door switch closed and then try the dispenser. It could the the dispenser switch.
