Kitchenaid Ice Not Making Ice #ksrg22fkwh04 - Appliances - DIY Chatroom Home Improvement Forum
Old 04-03-2009, 08:10 PM   #1
stevefastv6
Smile
kitchenaid ice not making ice #ksrg22fkwh04
check fill tube is not frozen first! if not unplug the unit from the wall. power to refrig. remove ice maker from freezer 3 screw 2 on door 1 for the ice maker will slide out .unplug ice maker from inside of freezer .remove square cover from side of ice maker. if possible remove module assembly pn#628399 from the side of ice maker 3 bronze colored screws . test fuse in wiring harness w/ volt/ohm meter .fuse is attached to mold heater assembly pn#2212351 . should be 0.00 resistance . diagram @ kitchenaid.com look for burnt contacts from motor failure! replace module assemby about 90.00 dollars local appliance repair center. after you install new part plug refrig into wall . keep a close eye and ear on ice maker for about three hours hope this helps fastv6
stevefastv6 is offline   Reply With Quote
Old 07-27-2009, 12:47 PM   #2
we have a Kitchen Aid side by side fridge.
Model # is KSRS2SCS**O*
The problem we have is the ice will not dispense. The store where we bought the fridge said we were not using the ice maker enough, thus the ice was getting blocked up. That was not true. We can't us it as it won't let the ice out.
They said they were going to replace the door, that was 6 months ago, and now 6 months after the warrantly has expired and they now refuse to do anything.
Is there anyone else out there having the same problem with the ice not dispensing.
MsCharlie is offline   Reply With Quote
Old 07-27-2009, 07:53 PM   #3
stevefastv6
Talking
reply
if you searched the internet this a common problem with kitchen aid brand! follow my instructions in my post? is the ice maker in the top of freezzer or is it in the the door? i bet it is the timer module either way check local appliance part department !!!!!!! before buying kitchen aide if you have feel free to ask
Old Sryer Making Load Noise Thoughout Cycle. 68MHJCs Appliances 12 12-05-2008 07:51 PM
Tips for making HardiPlank seams as smooth as possible? CareBear Building & Construction 2 09-18-2008 06:53 PM
GE fridge (older model) motor(?) making a lot of noise as it runs, also leak! liileah Appliances 1 06-24-2008 12:32 PM
Stream Radiator - Pipes and Radiators are making noises gforce HVAC 6 01-02-2008 10:58 AM
Making bear totum pole Keith of Ronin Landscaping & Lawn Care 2 03-27-2005 02:22 PM
