Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-09-2009, 05:33 PM   #1
Kitchen Cooktop Downdraft Exhaust
I have one of these above and noted this type of ducting tape used to secure metal ducting to route the exhaust outside:
Nashua 324A
Is there anything special about this tape above and beyond regular foil tape, which is used in other parts of the metail ducting? The Nashua brand is directly attaching the exhaust assembly to the first part of the ducting, and regular foil tape is used elsewhere. I assume it's because of high temperature considerations.
Reason is that I may need to disassemble the ducting to clean it out or check to see if there's grease that needs to be cleaned out.
Also, do kitchen downdraft exhausts usually have great traps?
handy man88 is offline   Reply With Quote
Old 03-09-2009, 06:05 PM   #2
Remodeling Contractor
grease traps are only used in commercial kitchens. Metal backed duct tape holds up better in this type of installations. A plumbing and heating supply store will have it. Some box stores carry it also in the duct section.
Old 03-09-2009, 08:30 PM   #3
Thanks.
Old Kitchen Brick Exhaust MichaelWayne_71 HVAC 5 12-03-2011 10:22 AM
Bathroom exhaust vent in kitchen? dc4nomore HVAC 11 05-27-2009 01:06 AM
Exhaust for Cooktop Mcrick HVAC 3 01-03-2009 07:51 AM
Kitchen Remodel - Gap around CookTop Mickey53 Remodeling 4 11-08-2008 10:15 PM
Recirculating Exhaust Fan in Gas Kitchen - Good/Bad? Crashless Remodeling 5 03-08-2008 10:18 AM
