Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-20-2010, 08:47 PM   #1
Kitchen Aid refridgerator not cooling
RE: Kitchen Aid model# KSRA25FKSS00
I have a Kitchen Aid fridge that has stopped cooling.
When I plug it in, I can hear a low hum, like it would normally sound when it is plugged in and running. Later I will hear what sounds like a motor starting, and will stay on for about 5-10 seconds and then shut off. It will then try to start up again about 10 minutes later. It will continue this cycle about 10 times, at which time the internal alarm will go on.
I have trying unplugging and reseting the fridge with no luck.
I think part of the problem may have been that several cans of pop were put in front of one of the vents inside the fridge, nearly completely blocking it.
I was told by someone that had a similar problem that I would probably have to replace the "fuse". From looking at the parts I am suspecting that the reference to a fuse is either to the Starting Device http://www.appliancepartspros.com/pa...art_id=3885081 or the Overload Relay http://www.appliancepartspros.com/pa...art_id=3885081
Does anyone have any suggestions on what the problem may be, before I go out and buy these parts to experiment?
helpneeded22 is offline   Reply With Quote
help! bring my kitchen together NewlywedKristin Interior Decorating 10 10-26-2011 02:08 PM
kitchen design: should we remove inner wall(s)? ilyaz Kitchen & Bath Remodeling 4 10-26-2010 08:59 AM
Using same tile for bathroom and kitchen too Matchy-Matchy? Jeanene Interior Decorating 10 03-29-2010 01:38 AM
Painting Kitchen Cabinets, Back wall NewlywedKristin Interior Decorating 12 03-18-2010 11:23 AM
Ideas Regarding Kitchen Remodeling Kristal Kitchen & Bath Remodeling 2 12-20-2009 10:44 AM
