Kitchen Aid Range - Appliances - DIY Chatroom Home Improvement Forum
Old 01-31-2011, 10:49 AM   #1
kitchen aid range
bake element burnt out, replaced and still no oven, checked inline fuse o.k.
grahamfr is offline   Reply With Quote
Old 01-31-2011, 02:55 PM   #2
Rewards Points: 152
The next things that come to mind, in order, are to double check that the new element is properly installed, try switching the breaker off, then back on, and check the voltage at the receptacle, as well as at the element.
Old 01-31-2011, 05:07 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
check voltage to stove first if you have 220 V then I would have to say the pcb is bad
hardwareman is offline   Reply With Quote
Can NM come in contact with ductwork from residential kitchen range hood? northstar1 Electrical 2 12-13-2010 10:47 AM
kitchen cabinet mircrowave range marin001 Building & Construction 1 12-10-2010 05:32 PM
kitchen range exhaust design ericadami HVAC 2 10-18-2010 12:40 PM
Questions about ductwork for kitchen range hood ilyaz HVAC 11 12-09-2009 12:16 AM
looking for kitchen fan for range ventilation wombosi HVAC 2 12-30-2008 08:09 PM
