Kitchen Aid Dishwasher Doesn't Cycle/drain - Appliances - DIY Chatroom Home Improvement Forum
Old 11-15-2013, 08:05 AM   #1
Rewards Points: 35
Kitchen Aid Dishwasher doesn't cycle/drain
Kitchen Aid Superba
Model: KUDS24SEB1
Hi Guys,
Dishwasher is about 13 years old and when trying to start, the initial cycle works and water fills the dishwasher, but then nothing further happens. No sound whatsoever.
I tried to use the diagnostic by alternatively hitting the high temp/energy save buttons and it goes through the lights flashing, but nothing else happens. The water stays filled at the bottom and does not drain.
Any ideas?
Thanks for your help
Jay
jay235 is offline   Reply With Quote
Old 11-15-2013, 08:18 AM   #2
Rewards Points: 12,858
http://www.repairclinic.com/RepairHe...roubleshooting
Old 11-15-2013, 03:44 PM   #3
Rewards Points: 35
Doing some further diagnostic on the unit -Here is what I am seeing:
I removed the bottom panel and pulled out the 2 wires going to the motor. Then put the dishwasher in the auto diagnostic mode (which makes it go through the cycles), I am seeing only 104VAC going to the motor and not 120V.
Could this be my issue? Does it mean a bad control board?
Jay
Old 11-19-2013, 04:05 PM   #4
Rewards Points: 35
Pulled off the control board and on the back I see a the solder to a relay is all burnt. Will try to replace and resolder a new relay.
Old 11-19-2013, 04:59 PM   #5
K&B Designer
Live_Oak's Avatar
Jay, it's 13 years old. Time for a new one. And you'll be amazed at how quiet the new ones are! Even mid range DWs are quiet and efficient these days.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 11-19-2013, 05:23 PM   #6
Rewards Points: 35
I know. But it's all about DIY. Fixing it for $2 and seeing it if it lasts another 10 years is the name of the game.
Besides, there are no guarantees that buying a new one will last.
Old 11-19-2013, 05:50 PM   #7
Rewards Points: 144
If that doesn't work may have to replace board. Hey worth a shot, you got nothing to lose and you may get lucky. Hope everything works out for you.
jmon is offline   Reply With Quote
Old 11-19-2013, 06:16 PM   #8
Rewards Points: 35
Thanks Jmon. My thoughts exactly.
Old 11-21-2013, 07:35 AM   #9
Rewards Points: 35
I was able to remove the old relay from the control board and solder in a new one. DW is working now.
Old 11-21-2013, 10:58 AM   #10
Rewards Points: 144
Amazing. Great job.
2 Bathrooms and a Kitchen KevinACrider Project Showcase 16 10-31-2011 07:03 AM
Replacement of existing drain pipe from Kitchen and dishwasher RogerM Plumbing 1 10-13-2011 02:48 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 10:52 PM
smell in basement from non-vented kitchen sink ahgill Plumbing 3 10-11-2010 03:39 PM
Install a dishwasher in an existing kitchen cabinet shapeshifter Remodeling 9 03-16-2008 02:05 PM
