Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-05-2007, 08:35 AM   #1
Kitcheaid Freezer wiring Harness replacement
I have a Kitchenaid side by side Freezer/Fridge. I need to replace the wiring harness that runs through the Freezer door to the icemaker/water dispenser. Can anyone tell me how to dis assemble the freezer door? The Frige mode number isKSBS25FKBL00. TIA
db819 is offline   Reply With Quote
Old 03-10-2008, 02:12 PM   #2
The door on your fridge does not come apart like the older fridges.
Your fridge has a foamed in place liner.
You can take the dispenser a part by sliding a screwdriver in the slots on the bottom edge of the dispenser trim and popping the bottom edge off.
Then slide the trim up and off.
This will give you access to the inside of the dispenser.
Here is a good place to get Appliance parts if you require them.
girltech is offline   Reply With Quote
Old 03-11-2008, 10:55 AM   #3
Thank you for the reply. This very good to know.
Freezer tripping GFCI davidclements Appliances 40 10-15-2010 11:38 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 10:55 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
