-   -   Kitcheaid Freezer wiring Harness replacement (http://www.diychatroom.com/f47/kitcheaid-freezer-wiring-harness-replacement-11284/)
db819 09-05-2007 08:35 AM
I have a Kitchenaid side by side Freezer/Fridge. I need to replace the wiring harness that runs through the Freezer door to the icemaker/water dispenser. Can anyone tell me how to dis assemble the freezer door? The Frige mode number isKSBS25FKBL00. TIA
girltech 03-10-2008 02:12 PM
The door on your fridge does not come apart like the older fridges.
Your fridge has a foamed in place liner.
You can take the dispenser a part by sliding a screwdriver in the slots on the bottom edge of the dispenser trim and popping the bottom edge off.
Then slide the trim up and off.
This will give you access to the inside of the dispenser.
Here is a good place to get Appliance parts if you require them.
db819 03-11-2008 10:55 AM
Thank you for the reply. This very good to know.
