Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-15-2010, 11:23 AM   #1
Kicks on and off
Kobalt 20 gal compressor kicks on for only a second then kicks off. It does this over and over.
dakslim is offline   Reply With Quote
Old 05-15-2010, 11:28 AM   #2
Kicks on and off
bad press gauge? debris stuck in it?
The older I get the better I was
Old 05-15-2010, 12:33 PM   #3
Household Handyman
Kicks on and off
Definitely a pressure switching problem. Did you buy this unit new? Has it done this since YOU have had it? Have it ever been dropped so that it may have hit the pressure switch? It sounds as if the "cut-in" and "cut-out" pressure settings are too close. Do you have the manual for this unit so you can check the adjustment of the pressure switch settings? David
