Kennmore Spin Cycle Slipping - Appliances - DIY Chatroom Home Improvement Forum
Old 09-05-2013, 09:09 PM   #1
Rewards Points: 105
Kennmore spin cycle slipping
Kennmore 90 series washer. Just recently in spin cycle it's slipping. Takes a while to get up to top speed. Large load it won't even spin. Any help on this is appreciated, thanks.
gmbwrenchn is offline   Reply With Quote
Old 09-05-2013, 10:11 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Replace the belt.
Tilt the washer back and look at the belt, probably worn.
Easy to replace.
sublime2 is offline   Reply With Quote
Old 09-06-2013, 03:31 PM   #3
Rewards Points: 105
Thanks..........sounds simple enough. I like it!
Old 09-07-2013, 10:48 AM   #4
Roofmaster
Rewards Points: 2,172
yup, probably belt, but check to see if there is oil on it. The tranny might be leaking.
By the way, those belts are actually designed to slip at startup, so dont think somethings wrong if yours does. I had a good old tech out to work on a kenmore washer that was overflowing and he explained how they do that because its cheaper, and better than trying to build a torque converter that can handle start up resistance with various loads applied. Pretty clever and simple way to handle a complex problem. You have to have the exact right belt though, one that is impregnated with silicone so it slips. Dont try to use any old belt, it will tear up things in your gear case.
Old 09-08-2013, 02:21 PM   #5
Rewards Points: 105
Flipped the washer over to take a look. There is oil visible all around. I suspect tranny is leaking as mentioned by Jagans. So.........repairable? What are we talking, gaskets? Also, where is the belt located on this thing. See pic. Thanks for the help.
Old 09-08-2013, 03:23 PM   #6
Rewards Points: 105
I don't even think there is a belt on this model. #110.22912101
Old 09-08-2013, 05:13 PM   #7
Roofmaster
I dont either, now that I see it. Looks like a worm gear on the motor to a pinion on the shaft. go to parts tree, or Sears Parts and see what you have.
Old 09-08-2013, 05:18 PM   #8
Rewards Points: 105
Yea I did. It has a transmission in it. I would suspect that it's bad. Gotta be it. Go to searspartsdirect.com to see the parts diagram. Tell me what you think, thanks. Model # 11022912101
Old 09-08-2013, 06:06 PM   #9
Roofmaster
I would say that if you have several kids, and the washer is over 12 years old, its time to bite the bullet and buy a new washer. We have owned two front loaders, and we would never go back to a top load model, as the front loaders use much less water, and their high spin speed reduces the cost to dry your clothes significantly. They are rather expensive, but well worth the extra cost IMHO.
Its really a shame, but the cost of parts today usually renders repair a bad financial decision, especially if its a transmission.
Just checked, Tranny is $ 196 and change, right? and that assumes that is all you need. Probably not.
Just looked again. Odds are you developed a leak in the seal of the tranny, and oil was thrown onto the clutch drum above the tranny. Looks like what we used to call a centrifugal, or Mercury clutch, the faster the shaft spins the more the bands are applied by centrifugal force. Just for the heck of it, and if you are strapped, you might want to try spraying the clutch and bands with brake parts cleaner. If this works, maybe you can replace the seals and make sure the tranny has the correct amount of lubrication, and maybe clean up the drum and replace the bands. This is truly speculation, because I am not a washing machine tech. Just a pretty good mechanic regarding things mechanical. Not sure how handy you are, but its worth a try if you cant afford a new washer.
Old 09-08-2013, 06:24 PM   #10
Rewards Points: 105
Yea I know.........want to upgrade soon just a shame that it has to be that way with the cost of parts. I know what your saying and thanks for the advice. E-bay has some for a lot less. May go that route for now.
Old 09-08-2013, 08:16 PM   #11
Roofmaster
Good Move. It looks pretty simple under there. Nothing ventured, nothing Gained. input the part number on ebay, you might get really lucky. Most of my parts come from there. The thing with a clothes washer is how long can you be without it without the little lady blowing a head gasket. Keep that in mind when you choose the type of shipping. By the way most Kenmore's are made by Whirlpool, and the part numbers are often the same so check Whirlpool too. I get parts from appliance parts online in FL. Good prices.
Sorry, its appliance pros. Check this out, they have the clutch assy for 32 bucks, and maybe you can find the seal you need. http://www.appliancepartspros.com/pa...022912101.html
Old 09-09-2013, 06:34 PM   #12
Rewards Points: 105
Thanks for the continued advice and help! This is where we are at. Got it all ripped apart. ( Yea I'm a pretty handy guy ) Went in deep. Trans replacement is out. Not needed. Looks like I'm going to need just the clutch assembly and trans. shaft seal. Found them both on E-bay (unbelievable). Total parts: $42 bucks. Only thing I really need yet, which I can't find separately, is the gear lube for the transmission. Gotta be able to throw something in there that's viscosity close, eh? Wife is very patient while it's down. Thanks again, G
Old 09-09-2013, 07:42 PM   #13
Roofmaster
Found this for model 110.28942891: (check to see if they are similar) The total volume of oil inside the transmission is between 13-15 ounces of SAE non-detergent non-foaming 60wt motor oil. (Tractor Supply, maybe?)
By the way, check the snubbers if it has them, maybe yours are worn? Good Job Mate, my hat is off to you! Dont forget Lock-Tite Blue, and clean all your connections with CRC QD electronics cleaner (Wal-Mart)
Old 09-09-2013, 08:23 PM   #14
Rewards Points: 105
Sounds close enough to me. Good enough for a washing machine! Thanks for the other tips. Will do. We'll keep you up to date when I get her back up and running, G
Old 09-15-2013, 12:27 PM   #15
Rewards Points: 105
Update time.............works like it's brand new! Used 85w gear oil and thinned it out with some Mobile one 5w-30 and called it good. Replaced every seal in the trans. Also replaced the clutch lining which was the big one. The clutch lining was very worn from 12yrs. of usage. Seals were leaking oil into the clutch lining area, causing the tub to slip. Thanks for all your help and advice. You really helped made this repair a success for me. Gary
Spin cycle not working allison78ca Appliances 10 04-30-2013 02:53 PM
loud washer knocking/banging noise during spin cycle NABRIL Appliances 0 01-14-2013 01:51 PM
GE Washer vibrates like crazy in Spin Cycle medicpg Appliances 12 04-19-2010 11:36 AM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 04:03 PM
washer spin cycle seems wrong markm Appliances 5 01-04-2008 01:10 PM
