Kenmore (Whirlpool) Refrig Ice Maker Problem - Appliances - DIY Chatroom Home Improvement Forum
Old 01-14-2008, 04:26 PM   #1
Kenmore (Whirlpool) refrig ice maker problem
I have a Kenmore refrigerator, Model 106.56532400. The ice maker is the type with the ice bucket in the door, and the ice maker is at the top of the freezer compartment. A few days ago the ice maker quit making ice. There is no ice in the tray, so it's not just a matter of not dumping out the ice that's already been made. The water dispenser on the door works fine though. Periodically I hear a humming noise lasting about 5 seconds. This is a noise I've heard in the past after ice has been dumped.
After reading a bunch of posts in a couple of different forums, I'm leaning towards either a clogged/stuck valve, or a frozen fill tube. I'm going to try to take a look at both tonight to see if I can confirm that. Is the humming noise I hear indicative of anything that I can use to rule out a problem? Any other suggestions as to what I should be looking at?
The refrigerator also has a water filter. After replacing the filter every 4 months for a couple of years, I simply took it out the last time and never replaced it. How much could that add to the problem at hand?
Thanks,
joe.
lexort is offline   Reply With Quote
Old 01-14-2008, 05:12 PM   #2
Look inside and see if the arm that dumps the cubes is stuck.
redline is offline   Reply With Quote
Old 01-15-2008, 01:39 PM   #3
Your ice maker is electronically controlled.
Check the switch on the inside wall of the freezer to make sure that someone didn't accidentally shut the ice maker off.
To check the emitter and receiver open the freezer door and activate the door switch 3 times, and close the door for 2 seconds.
Open the freezer door and view the LED output code.
The light should pulse twice and then pause and then pulse twice.
Check the continuity of the fill valve at the back of the fridge.
To check the ice maker and optics receiver unplug the fridge then plug it back in.
You have 60 second to open the freezer door and view the LED output code.
For the ice maker you will have 3 pulses then a pause and then 3 pulses.
For the optics receiver you will have 4 pulses then a pause and then 4 pulses.
The emitter and receiver will be check again in this test with 2 pulses then a pause then 2 pulses.
If the system is good the light will be on for 5 seconds.
When you know what you need you can get appliance parts here.
Not having a water filter will not effect the ice maker.
girltech is offline   Reply With Quote
Old 01-15-2008, 04:02 PM   #4
Thanks for the thorough response. Last night I took a hair dryer to the fill tube, and after a while a chunk of ice dropped out. An hour or so later I had to repeat the process since the tube had refrozen. This morning I had a few batches of ice in the ice bin, and it was continuing to make ice when I left the house a couple of hours later.
So it seems a frozen fill tube was/is the culprit. The question I have now is whether this will be an on-going problem, and if so, what can I do to avoid it?
Old 01-16-2008, 08:31 AM   #5
I do believe that you will have the problem again.
You should call Sears as they may have a warranty issue with this fridge.
Here is a part number for a kit that will fix the problem.
The part number is 4389174.
This is a kit that has a new fill tube and a heater kit.
Old 01-16-2008, 08:56 AM   #6
The part number, 4389174, shows as "no longer available" using the link provided above. When installing this part, where do you tap into an electrical source to provide power for the heater?
Thanks again.
Old 01-16-2008, 01:24 PM   #7
The wiring for the ice maker is used a source of power for the kit.
It does show that is no longer available from Partselect but whirlpool shows that it is available.
Your fridge is a Whirlpool that was made for Sears this is why I suggested you call Sears.
Sometime there is a rework that is done under a special warranty.
This will depend on the age of your fridge and the serial number.
This is the case in Canada but I don't know how Sears in the USA deals with this type of issue.
Old 03-22-2008, 11:32 AM   #8
kenmore ice maker stopped working
I am having the exact same problem with my kenmore. I guess I need to try and mess with the fill tube. Do I need to dis-assemble the ice maker thingy to get access to the fill tube?
thanks,
lono
Parker, CO
lono33 at comcast.net
Lono is offline   Reply With Quote
Old 03-24-2008, 12:47 PM   #9
Lono
You should not have to remove the ice maker.
Can you provide me with your model number?
Old 06-11-2008, 01:59 PM   #10
Kenmore Ice Maker
Hi, I'm having the same exact trouble as Lono. I replaced both emitter cards, the optics appear to be working fine according to the LED codes. The arms that rotate and release the ice work, but no ice. I suspect a line problem, but I've looked behind the unit and noticed no blockage (the lines are transperant). The water is flowing just fine from the water dispenser on the door. The filter was recently replaced.
Should I be checking the line for blockage elsewhere?
Hump86 is offline   Reply With Quote
Old 06-11-2008, 05:08 PM   #11
jeff1's Avatar
Hi,
Maybe at the fill elbow?...
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 06-12-2008, 10:43 AM   #12
Kenmore Ice Maker Not Working
Thanks Jeff1, I will try your suggestion this evening.
Old 06-12-2008, 11:17 AM   #13
jeff1's Avatar
Your welcome.....fingers are crossed that is your problem
jeff.
JRAppliance
www.jrappliance.ca
Old 08-07-2008, 05:24 PM   #14
Ice maker is giving me the same problems
I have a Kenmore 106 56546400. The other day it stopped making ice. I found the extractors in the down position frozen in small ice cubes. I removed the ice maker and removed the ice. I reinstalled the maker but nothing has happened for the last three days. I did the check described above. After I unpluged and pluged the fridge in the LED blinked three times right after I opened the door. It then went to two blinks with a pause and two blinks. Going by the info above does that indicate that the ice maker its self is bad?
SLOLIFEPILOT is offline   Reply With Quote
Old 08-25-2008, 07:53 PM   #15
can't find the switch
charlespatel1960 is offline   Reply With Quote
Whirlpool refrig. problem ken1415 Appliances 147 02-25-2017 01:27 PM
Whirlpool fridge ice maker not working hlewis77 Appliances 12 12-10-2011 11:44 PM
Whirlpool Ice Maker Control Kaput? Mike Swearingen Appliances 11 06-09-2011 07:46 AM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 03:07 PM
Kenmore Refrig. Temp. ? kourso Appliances 1 07-09-2007 12:37 PM
