Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-31-2008, 12:46 PM   #1
Res Ipsa Loquitur
Kenmore (Whirlpool)DW with dirty top rack
For those familiar with Whirlpool dishwashers-
I have Kenmore model 665.16483300 (Whirlpool) that started acting up (again) with poor cleaning of the top rack dishes. I took apart the lower pump covers and found the inlet masher screen covered with food bits. At first I thought it was just dirty (as it was before) then it came to me to check a few different times after turning the unit on and off. I found the blade mashing the screen was not turning as it was supposed to.
After looking over the gear (to the masher) it doesn't appear to be damaged where linking to the motor shaft. This part is easily replaceable. Is it likely that the motor shaft is damaged and how do I go about fixing that- is it a full motor replacement or is just the shaft (or end gear) replaceable?
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 05-31-2008, 03:36 PM   #2
jeff1's Avatar
Hi,
Check the sump check valve for being deteriated as well.
Check valve, pump sump
Chopper assembly
Circulation motor and impeller assembly
Wash impeller and seal kit
Or the whole thing...
Pump and motor assembly, circulation
jeff.
Appliance Repair Aid
JRAppliance
jeff1 is offline   Reply With Quote
Old 05-31-2008, 06:28 PM   #3
Res Ipsa Loquitur
Thanks- I guess I'll have to get deeper into the motor other than just at the chopper level!
Old 05-31-2008, 11:26 PM   #4
jeff1's Avatar
This link here may help as well.
jeff.
JRAppliance
Dishwasher - top rack no water pressure jbomber Appliances 5 12-18-2006 05:49 PM
