-   -   Kenmore (Whirlpool)DW with dirty top rack (http://www.diychatroom.com/f47/kenmore-whirlpool-dw-dirty-top-rack-21676/)
handyman78 05-31-2008 12:46 PM
For those familiar with Whirlpool dishwashers-
I have Kenmore model 665.16483300 (Whirlpool) that started acting up (again) with poor cleaning of the top rack dishes. I took apart the lower pump covers and found the inlet masher screen covered with food bits. At first I thought it was just dirty (as it was before) then it came to me to check a few different times after turning the unit on and off. I found the blade mashing the screen was not turning as it was supposed to.
After looking over the gear (to the masher) it doesn't appear to be damaged where linking to the motor shaft. This part is easily replaceable. Is it likely that the motor shaft is damaged and how do I go about fixing that- is it a full motor replacement or is just the shaft (or end gear) replaceable?
jeff1 05-31-2008 03:36 PM
Hi,
Check the sump check valve for being deteriated as well.
http://www.repairclinic.com/dbImages...4/00083057.jpg
Check valve, pump sump
http://www.repairclinic.com/dbImages...8/00072290.jpg
Chopper assembly
http://www.repairclinic.com/dbImages...3/00264028.jpg
Circulation motor and impeller assembly
http://www.repairclinic.com/dbImages...0/00320041.jpg
Wash impeller and seal kit
http://www.applianceblog.com/dishwashers/DSCF1132.jpg
Or the whole thing...
http://www.repairclinic.com/dbImages...2/00082259.jpg
Pump and motor assembly, circulation
jeff.
handyman78 05-31-2008 06:28 PM
Thanks- I guess I'll have to get deeper into the motor other than just at the chopper level!
jeff1 05-31-2008 11:26 PM
This link here may help as well.
jeff.
