Kenmore Water Softner - Appliances - DIY Chatroom Home Improvement Forum
Old 12-11-2007, 10:29 PM   #1
kenmore water softner
I have a model 625.3484500 kenmore water softner. I get a error 3 message on the display. When I remove the electrical plug and plug in back in, the motor continues to run. The cam and gear tries to move and at some point just snaps back to a frozen position. The manual says the code meas the motor is inop or face plate problem. Since the motor continues to run, it can not be inop. The face plate is just a plastic cover in which I can not figure out what this has to do with the problem. Anyone have any suggestions to help fix this problem.
Thanks!
homerepair is offline   Reply With Quote
Old 12-12-2007, 03:12 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not water softener tech by any means, just a long-time DIYer.
I would unplug the unit and lube the cam, gears, etc. with WD-40. I've done that on mine before and it has straightened it up.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 08:55 PM
water softner repair ranchody General DIY Discussions 3 05-28-2007 01:41 PM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
water softner BIGJIMold Plumbing 4 12-26-2006 08:35 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
