Kenmore Water Dispenser Stopped Suddenly - Appliances - DIY Chatroom Home Improvement Forum
Old 03-05-2013, 07:20 AM   #1
Kenmore water dispenser stopped suddenly
Hi again. Some time ago I posted here ( I think here) about my ice maker not filling with water. ( I have tried to find the old post,but no luck!) As it happened I found a small piece of solder (I think it was) in the line. Thats fixed, but now the water dispenser in the door has suddenly stopped. I have taken the line off and blown through it looking for another obstruction, and it is clean. When I push the lever for water there is a slight hum behind the fridge so it seems the solenoid is working (?). The last time some kind soul posted complete instructions, with diagrams on how to check the solenoid and water valve in a Kenmore model # 106-59082891. I wonder if that kind individual is still here and willing to help a novice again? Thanks
Houseman62 is offline   Reply With Quote
Old 03-05-2013, 08:29 AM   #2
I believe I have the problem, may be frozen where it goes up through the door to the dispenser. Will try to thaw it and see what happens.
Old 03-08-2013, 11:38 PM   #3
Pull the kick plate pull coupling from under the door see if you get water there if you don't bad water valve.
rkentzel is offline   Reply With Quote
Old 03-10-2013, 08:40 PM   #4
Actually did that as well, but found it was frozen in behind where the lever is for dispensing. 15 minutes with a fan blowing in there cured it. By the way, is saw from the Sears website for parts there is a heater in there. Any idea how to remove the front panel around the dispenser to replace it? (the heater I mean)
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 12:47 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Kitchenaid water dispenser NOT dispensing nvrrong Appliances 7 12-05-2011 08:36 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
