Kenmore Washwasher - Appliances - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 09:34 AM   #1
kenmore washwasher
hello
how do you remove boot on front load washer
Kenmore model #41742052100 it does not seem to have a spring
thank you I am trying to replace the door switch do I have to remove the boot to do this
Last edited by mark hurley; 04-24-2013 at 07:09 PM. Reason: more iformation needed
mark hurley is offline   Reply With Quote
Old 04-24-2013, 10:43 AM   #2
Rewards Points: 744
Kenmore is made by Frigidaire. Watch this video for disassmbly instructions:"
http://www.repairclinic.com/Video/VLVideoLayer/371
Seattle2k is offline   Reply With Quote
Old 04-24-2013, 12:10 PM   #3
kenmore washer
Thanks for the video. My machine is different it is an older model there does not seem to be a spring around the boot.
thanks
Old 04-24-2013, 12:22 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
removal of the boot is not an easy task. Yes there are springs holding it in, you probably just can not see it. You will be tearing this machine down quite a ways to replace that boot. Just for an idea, you will have to remove the top, remove the control panel, remove the entire front. Reinstalling the new boot is harder than removal so if you are not a super handy DIYer you may want to hire it done.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
kenmore water softener Squiddly Plumbing 6 11-16-2011 07:51 AM
Bradford White or Kenmore HWH? Durt Ferguson Plumbing 0 03-07-2011 01:54 PM
How much does it cost to operate my Kenmore freezer? sofasurfer Appliances 2 01-25-2011 12:46 PM
Kenmore Range Kajunkind Appliances 0 02-24-2010 08:44 PM
Kenmore Icemaker install Turnerg110 Appliances 2 07-21-2008 03:55 PM
