Kenmore Washer Won't Spin - Appliances - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 02:59 PM   #1
Kenmore washer won't spin
I have a Kenmore 80 series (model 110.23832100) washer that only spins sometimes (when it wants to, I guess). other times, you can hear the motor running but it doesn't spin. If you lift the lid far enough to reset the switch and re-close it, there's a sound like a brake releasing and it spins fine. I've checked the lid switch for continuity and it's working properly, I haven't gone any farther than that but the wife's patience is starting to run low... Thanks in advance for any help!
TNFrank is offline   Reply With Quote
Old 01-10-2011, 05:19 AM   #2
if it spins ok after you lift the lid it sounds like timer is bad. it's supposed to neutral drain [tub not turning]and then stop[this releases trans]then spin [which is what you're doing manually]...for a DIY'er =put in rinse cycle and wait for it to go through rinse, spin cycles-see if it stops in spin and then takes off...if not=timer.
Jacques is offline   Reply With Quote
Old 01-10-2011, 05:19 PM   #3
Thanks, Jacques. I tried this twice today - the first time it went through the cycle completely, including spin, and the second time it drained and stopped. Opened the lid and closed it and it started spinning. Makes sense that it's a timer problem, I'll get a new one and install it. Thanks again!
Old 01-11-2011, 08:13 AM   #4
it's supposed to drain[no spin] then stop, then restart and spin. usually what will happen is; it will never stop-just keep running [no spin]until hits OFF..is this what you observed??
Old 01-11-2011, 05:52 PM   #5
No, it stops after draining and restarts, but doesn't spin unless we lift and re-close the lid, then there's a mechanical sound like something engaging or disengaging and it starts spinning. But it only does it sometimes, other times it goes through the entire cycle without any problem.
Old 01-12-2011, 07:03 AM   #6
Well if it stops and then restarts it should spin[that's all you're doing when you lift the lid-allowing the gear to release=clunk sound]. if it needs coaxing, may have bad trans.
ugh.... my kenmore washer won't fill with water! diy'er on LI Appliances 6 09-05-2010 07:28 PM
GE Washer will not perform final spin joeycranston Appliances 6 01-18-2010 11:06 PM
GE washer No spin when loaded SPSNEXPERT Appliances 4 06-29-2009 12:39 AM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 04:03 PM
washer spin cycle seems wrong markm Appliances 5 01-04-2008 01:10 PM
