Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 04-24-2008, 12:05 PM   #1
Learning by Doing
Leah Frances's Avatar
Kenmore washer won't drain! How do I get the water out?
My Kenmore clothes washer, model no. 92598200, won't drain. When engaged in the 'drain' portion of the cycle it makes a clicky noise and does nothing.
Without knowing anything, I would guess something broke, right?
I feel comfortable taking it apart and fixing it - but it is full of hot bleachy water. What's the best way to get the water out so I can troubleshoot it?
Oh yeah, it won't spin or add water either.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-24-2008, 12:52 PM   #2
Learning by Doing
Hah! I have a wet/dry vac!
Old 04-24-2008, 02:17 PM   #3
jeff1's Avatar
Hi,
model no. 92598200
Missing some digits.
I got 110.92598200 to work for me.
A Whirlpool built Kenmore, direct drive style.
Lay the drain hose down to the floor drain or in a bucket, shop vac.
Some access helps...
http://www.applianceaid.com/procedures.html
jeff.
Appliance Repair Aid
JRAppliance
jeff1 is offline   Reply With Quote
Old 04-24-2008, 02:39 PM   #4
Learning by Doing
Hey Jeff, thanks for the suggestions. The washer was too heavy, while full, for me to move it enough to get to the drain pipe by my self. I used my shop vac to suck out the water. Now I have a sink full of wet, partially clean, laundry and a broken washer.
The Kenmore (you were right about the missing 110 - sorry) came with the house I bought last year. For now, I will swap it with my front-loader (I brought it when I moved, but was too lazy to swap them at the time).
The Kenmore will head to the basement and wait for troubleshooting. Given it's model number, is it worth trying to fix?
Old 04-24-2008, 06:47 PM   #5
jeff1's Avatar
Definetly worth checking and finding out what is wrong and what is required to correct the problem. Direct drive washers often will go 8-10 years easily with only minor repairs.
jeff.
JRAppliance
Kenmore washer won't drain diggitydog Appliances 3 10-16-2010 11:46 PM
Water Softner Overhead drain MIWW Plumbing 1 02-27-2008 10:07 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 01:27 AM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
