Kenmore Washer Won't Drain. - Appliances - DIY Chatroom Home Improvement Forum
Old 11-20-2008, 07:29 AM   #1
Kenmore washer won't drain.
I have a Kenmore washer model 110.26912691. It's appear to agitate fine but when it got to the rinse/ drain portion of the cycle it stops. I would like to have help with a diagnosis so don't replace something I do not need to? Does it appear to a pump only issue?
Thanks,
Razburn
razburn is offline   Reply With Quote
Old 11-30-2008, 08:25 PM   #2
The timer has to reverse the motor for it to drain and spin. If it agitates fine but always just stops after washing and never spins or pumps, the timer is bad. You might try another cycle. If it never agitates again, the coupling is broken between the motor and gear case.
hoistdoctor is offline   Reply With Quote
Kenmore washer won't drain diggitydog Appliances 3 10-16-2010 10:46 PM
Washer tray drain plug proofer Appliances 5 08-24-2008 08:53 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 10:35 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 12:27 AM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
