-   -   Kenmore washer won't drain. (http://www.diychatroom.com/f47/kenmore-washer-wont-drain-32254/)
razburn 11-20-2008 08:29 AM
I have a Kenmore washer model 110.26912691. It's appear to agitate fine but when it got to the rinse/ drain portion of the cycle it stops. I would like to have help with a diagnosis so don't replace something I do not need to? Does it appear to a pump only issue?
Thanks,
Razburn
hoistdoctor 11-30-2008 09:25 PM
The timer has to reverse the motor for it to drain and spin. If it agitates fine but always just stops after washing and never spins or pumps, the timer is bad. You might try another cycle. If it never agitates again, the coupling is broken between the motor and gear case.
