Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-07-2008, 11:47 AM   #1
reluctant handyman
diggitydog's Avatar
Kenmore washer won't drain
Hello All,
I have an older Kenmore Heavy Duty 80 Series washer (110.82980120) that will no longer drain. It goes through the wash cycle, but just sits for hours when it hits the drain cycle. If I go to the spin cycle, it will spin but again stalls when it hits the drain cycle.
I pulled the output hose, and it does drain by gravity. The hose is free and clear, and the output does not seem to be blocked/clogged.
What are the possible causes of this? Is it a doable repair for a semi-handy person such as myself?
Thanks in advance!
diggitydog is offline   Reply With Quote
Old 01-07-2008, 12:10 PM   #2
Check and see if the washer will spin when it is empty.
If it will spin then the motor is good and the pump will have to be replace.
The motor reverses to drain the washer and spin.
The part number for the pump is 3349322.
Here is a good place to get appliance parts.
girltech is offline   Reply With Quote
Old 01-07-2008, 05:23 PM   #3
reluctant handyman
diggitydog's Avatar
Thanks for the info. I'll check it out and get back with the details.
Old 10-16-2010, 11:46 PM   #4
i just purchased a kenmore portable dishwasher from an auction at my job. i just tried to run it and it is not draining. totally clueless as to why
olatutu is offline   Reply With Quote
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 08:30 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 01:27 AM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
running washer drain sedwick Plumbing 8 02-12-2007 06:10 PM
