Kenmore Washer Will Not Run - Appliances - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 06:11 PM   #1
Rewards Points: 18
kenmore washer will not run
My kenmore washing machine will not run. It fills with water then cannot start. It will sometimes start if I remove all of the clothes and most of the water. I hear a hum like the motor is trying to start for a few seconds then it stops. I do smell a slight burning. The drive coupler is intact. I suspect the motor is worn out, Or could it be the start capacitor that is failing. Motor is $80.00, start cap is $4.00.
LiL-Daddy is offline   Reply With Quote
Old 10-24-2011, 06:11 PM   #2
How did the belt look?
Master of Cold is offline   Reply With Quote
Old 10-25-2011, 05:49 AM   #3
Before you buy any parts; check wire at motor. one may be burned or loose..if not, i would have it checked. you're going to end up throwing parts at it.
Jacques is offline   Reply With Quote
Kenmore washer won't drain diggitydog Appliances 3 10-16-2010 10:46 PM
ugh.... my kenmore washer won't fill with water! diy'er on LI Appliances 6 09-05-2010 07:28 PM
Kenmore Washer - Agitator not moving gdoucette Appliances 1 06-23-2010 09:09 PM
Kenmore washer problem wink25 Appliances 1 03-16-2009 07:02 PM
Lid Switch for Kenmore washer Steve76 Appliances 6 01-04-2008 12:44 PM
