10-29-2012, 10:46 PM
#1
Kenmore Washer stops working at drain point in cycle
Our Kenmore washing machine (Heavy Duty 80 Series - Model # 110.82982100) stopped working last night right after the wash cycle was completed. I tried to restart the cycle and it would agitate fine but once that was done, it would just stop. I drained the water out and disconnected the hose in the back and found nothing clogging the line. The rest of the water also came out of the machine so there doesn't appear to be anything clogging the line further up.
When I restarted the wash cycle twice and to checked it and it stopped at the drain point again, I did not hear any kind of pump or motor noise or anything. It is like it just cuts off dead so I am thinking that it is an electrical problem and I am leaning towards the lid switch but any other ideas would be appreciated.
I guess my question is how to test that lid switch. I do have a multimeter but my skills are moderate at best.
10-29-2012, 10:54 PM
#2
10-30-2012, 09:04 AM
#3
#1 HAWKEYE FAN
drop the control panel, you will see a three wire connector . Unplug it and ohm the 2 outer wires, with the lid closed you should have continuity
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
10-30-2012, 10:41 AM
#4
Bombastic Idiot
Oh, hardware you jumped a step.
Turn off breaker, unplug washer then do hardeware's test. All ohm tests are done with power off and all wires disconnected from part being tested.
Eagle, you sure you got that model number right?
Does machine agitate with door open? A few washers will not. If yours agitate closed but not open it is not door switch.
If you turn selector knob into rinse cycle, door closed, does washer try to spin? If it does it is not switch. A few washers will not spin if water level is too high, so try this with tub empty.
Is your drain hose hard connected to drain pipe or just hooked over stand pipe? If connected main line may be clogged.
"The rest of the water also came out of the machine..." The water ran out thru the pump? " I did not hear any kind of pump or motor noise" The pump has to lift the water up to the stand pipe, but water will drain down and out thru a pump that is not working. Water can drain thru a pump that has something blocking impeller so look thru both hose connectors. If your pump looks like the one in joe's link, disconnect the two wires ( breaker off washer unplugged, we don't want you jumping all around, sparks flying out ears.) Ohm meter connected to tabs on pump should read 5 to 10 ohms.
Connect ohm meter to the two wires, turn selector to off, you should get infinty on meter. Turn selector to drain cycle and should get a very low resistance.
If you can determine which wires from selector go to pump and door switch. You can connect ohm meter to tabs on selector and selector to drain. Without wiring diagram, which I can't find for model number given, I cant tell you which tabs to check with which, and which wires need to be disconnected from selector to prevent false reading. There may be a wiring diagram pasted to inside of an access panel or rolled up inside control panel.
Hardware is liable to jump all over me again if I tell you how to isolate lid switch from pump circuitry and pump from lid, even with power off, so if he thinks doing so would help in diagnoses I'll let him tell you.
I suspect the pump, from your description, then lid switch or circuitry to and between them. Pump is around $30, not to great amount to try swap out, but why spend it if you can use ohm meter. And many parts dealers will not take returns of electrucal parts.
Measure twice, cut once. Look at the nail, not the hammer. Watch the fence, not the blade. If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
10-30-2012, 04:25 PM
#5
#1 HAWKEYE FAN
quit confusing the guy,his machine does not have an electric pump,or pump circuitry, it is a belt driven pump........... So check door switch first.
10-30-2012, 04:28 PM
#6
#1 HAWKEYE FAN
sorry, it is not belt driven it is coupler driven. Same advice check lid switch FIRST
10-30-2012, 06:17 PM
#7
Ok, I have the washer casing off and have done a few checks already. I pulled off all the hoses and the impeller pump and nothing is clogged in them. Thanks for addressing the pump circuitry issue Hardwareman as I was indeed a little confused by Notmrjohn's suggestion to check the ohms on the pump. It is driven by the washer motor and, as you stated, there is no belt but a coupler. To address the other questions that Notmrjohn had, the model number was taken right from the nameplate on the washer, the machine WILL agitate with lid open, turning selector knob to rinse will not cause it to spin (and water was at the Low level) and finally, the drain hose is hooked over a stand pipe.
I checked the lid switch by removing the wires at the switch and putting the meter probes on the switch tabs there. There IS continuity....unfortunately for me as that would have been an easy fix I suppose. I also probed the lid switch wires at the connector and found continuity there as well.
Thanks for the help so far. What should I address next?
10-30-2012, 06:32 PM
#8
#1 HAWKEYE FAN
ok, manualy put timer into the spot where washer will spin, what happens? Is it dead or does it take off? I suspect you may have a dead spot in the timer.
10-30-2012, 10:28 PM
#9
Ok, I plugged it back in, turned the selector dial to the diamond symbol, which, I believe is the spin cycle and pulled out on the button and got nothing. I also tried it on a different cycle and got the same and I also tried at the drain/rinse point which I believe is the asterisk but there is nothing happening.
10-30-2012, 11:14 PM
#10
#1 HAWKEYE FAN
if your 100% sure about the lid switch being good then you have a bad timer
10-30-2012, 11:19 PM
#11
When I did the test you just recommend, I did NOT have the lid switch connected. Did I need to connect that to run a fair test?
10-30-2012, 11:44 PM
#12
Is there any other way to test the timer to be sure? The timer is pretty expensive new but I could pick up a used one if necessary.
10-31-2012, 08:56 AM
#13
#1 HAWKEYE FAN
absolutely
10-31-2012, 11:14 AM
#14
Ok, with lid switch connected I tried the test again and got nothing on the spin cycle. That is assuming that the spin cycle is the diamond mark on the panel....
I tried a few times using other wash cycles too and got no spinning. I also tried it at the asterisk, which I think is the marking for the rinse cycle. Water started coming into the washer tub (I quickly shut it off). It wanted to start the rinse cycle now that the tub is empty.
11-05-2012, 10:49 PM
#15
So I purchased a used timer and found it to be defective after installing it. When I go to push in the knob to turn it to a cycle, the water starts immediately and it should not start until I pull the knob out. The whole 'in and out' action is much too loose and just defective. So now I have to return this one and get another.
When I had MY timer out though, I was looking at it and when I compared its functioning to the other used one I just bought, it seemed to work a lot better. I didn't see any signs of broken pieces on the timer wheel, bad or burnt contacts, etc.
So I am wondering if I can test this somehow with my multimeter? I want to be sure I need to replace this as this is going to cost me more time and money to be chasing the wrong part.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
