Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-16-2009, 05:00 PM   #1
Kenmore washer problem
I have a kenmore washer. I was doing laundry and the cold water would not shut off and the washer overflowed. I tried to wash again and it is doing the same thing. Any ideas of what is wrong and can I fix it or should I scrap it?
wink25 is offline   Reply With Quote
Old 03-16-2009, 08:02 PM   #2
Sounds like your inlet valve is bad. you can pull up yor model no on Sears parts direct,get part number,probably get it cheaper, at local parts hose.
d scott is offline   Reply With Quote
Kenmore (Whirlpool?) Ice maker problem reddog6 Appliances 4 10-09-2011 07:11 AM
Washer Drain line extention Born In America Appliances 1 02-28-2009 04:55 PM
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 12:00 PM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 07:10 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
