Kenmore Washer Not Agitating/Spinning - Appliances - DIY Chatroom Home Improvement Forum
Old 10-28-2012, 12:24 PM   #1
Rewards Points: 49
Our Kenmore washer (70 Series, Model 22722100) recently stopped agitating and spinning. It fills up OK, and then when it should agitate or spin, there's a hum like the motor has seized up.
Is there much to replacing the motor on this model?
Cultcab is offline   Reply With Quote
Old 10-28-2012, 12:32 PM   #2
Rewards Points: 13,732
http://www.repairclinic.com/RepairHe...te-11022722100
Old 10-28-2012, 01:28 PM   #3
Bombastic Idiot
notmrjohn's Avatar
Before you get all agitated about replacing motor read this. You may have something as simple as loose belt.
Read especially section 2-5 http://www.appliancerepair.net/washi...-repair-2.html
Specific to Kenmore, read everything thru section 3-3 http://www.appliancerepair.net/washi...-repair-3.html
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 10-28-2012, 07:00 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
that washer would not have a belt. You probably have a broken motor coupler.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
kenmore washer twinkstar Appliances 0 02-14-2012 12:29 PM
Kenmore washer raye321 Appliances 2 07-04-2011 12:28 PM
Kenmore washer won't drain diggitydog Appliances 3 10-16-2010 10:46 PM
ugh.... my kenmore washer won't fill with water! diy'er on LI Appliances 6 09-05-2010 07:28 PM
Kenmore washer problem wink25 Appliances 1 03-16-2009 07:02 PM
