Kenmore Washer Banging During Agitation - Appliances - DIY Chatroom Home Improvement Forum
Old 06-02-2009, 05:12 PM   #1
Kenmore (Whirlpool)
110.82382110
Belt Drive
I'm getting a clanging noise (metal against metal) about once every second during the agitation phase. Also, The auger is only intermittently turning clockwise (louder the bang, less of the clockwise movement). Instead of the auger rotating back and forth, it's pretty much only going in one direction. I'm getting some cw movement if the washer's been off for a few days, if I turn it off and on a few times or if the water level is a certain height, but, otherwise, the clothes just spin around in a circle instead of agitating. If I have sheets in the wash, the sheets will go underneath the auger, twist around the inside and stop the movement completely.
Does anyone know what might be causing this?
scott123 is offline   Reply With Quote
Old 06-03-2009, 10:20 PM   #2
Quadfam4's Avatar
my husband says it could be the tranny or the agitator dogs.
Quadfam4 is offline   Reply With Quote
Old 06-03-2009, 10:45 PM   #3
Say it Is not so!!!!
Broken retaining/counteracting/stabilizing spring(s).
Start here:
http://www.searspartsdirect.com/part...2110&pop=flush
MALCO.New.York is offline   Reply With Quote
Kenmore washer won't drain diggitydog Appliances 3 10-16-2010 11:46 PM
Kenmore washer problem wink25 Appliances 1 03-16-2009 08:02 PM
Kenmore washer won't drain. razburn Appliances 1 11-30-2008 09:25 PM
new HE5 kenmore washer sninny Appliances 4 08-08-2008 04:24 PM
Lid Switch for Kenmore washer Steve76 Appliances 6 01-04-2008 01:44 PM
