Kenmore Washer - Appliances - DIY Chatroom Home Improvement Forum
Old 06-29-2011, 05:10 PM   #1
Kenmore washer
I have a apartment size kenmore washer with the dryer on top. Model #417'98702891. I will not drain. I have fixed this problem before by raising the hose in the back or lowering it. but this time that doesnt seem to be working. I have checked it anything is clogged up. nothing seems to be. Water is coming out of the tub, comes out of the pump, pump seems to be working, If the tub is full and I put it on spin if I lower the hose in the back it will drain but then it will not fill. If I raise the hose it will fill but will not drain
raye321 is offline   Reply With Quote
Old 06-30-2011, 09:51 AM   #2
Lowering the hose is just letting it gravity drain, which is why it won't fill-just runs right out. since it will gravity drain [means not clogged] it has to be pump or pump not getting power.
Jacques is offline   Reply With Quote
Old 07-04-2011, 01:28 PM   #3
Adrien's Avatar
Hi,..
Kenmore is the great brand for the washer its durable also and cheap in prince ..
Adrien is offline   Reply With Quote
Kenmore washer won't spin TNFrank Appliances 5 01-12-2011 08:03 AM
Kenmore washer won't drain diggitydog Appliances 3 10-16-2010 11:46 PM
ugh.... my kenmore washer won't fill with water! diy'er on LI Appliances 6 09-05-2010 08:28 PM
Kenmore washer problem wink25 Appliances 1 03-16-2009 08:02 PM
Kenmore Top Load Washer gone Crazy ! kourso Appliances 1 07-09-2007 12:48 PM
