Kenmore Topload Washer Tripping Breaker - Appliances - DIY Chatroom Home Improvement Forum
Old 09-28-2009, 08:43 PM   #1
Kenmore Topload Washer tripping breaker
Hello, We have a Kenmore 80 series heavy duty top load washer. The issue we are having is that it tripped the breaker after running for about 1 min. After resetting the breaker, it runs for about 30 secs. then stops, it sounds like it is running under a heavy load. Any suggestions on where to start to trouble shoot would be much appreciated.
Thank you,
mdavis
mdavis317 is offline   Reply With Quote
Old 09-29-2009, 08:40 PM   #2
get access to the motor and see if its arcing under an agitation cycle. Does the breaker trip after the water has just got done filling and the agitation starts or maybe after the washer starts to spin. See if you can pinpoint when it trips. hope this helps.
Lou
ibzbro is offline   Reply With Quote
Old 09-29-2009, 09:14 PM   #3
Breaker tripping on Kenmore topload
Ibzbro,
Thanks for the reply. The washer tripped the breaker twice, it has'nt tripped the breaker anymore. But the washer seems to be running in slow motion now, and will just stop running for like 30 secs. then start again.
Old 10-02-2009, 10:17 PM   #4
probably your motor but it's hard to tell without more info. if i had to guess with the information given i would say its the motor.
Old 10-04-2009, 08:26 AM   #5
Kenmore Topload 80 Series
We had a friend come out and trouble shoot it, he is a appliance repairman, and he found it to be the motor switch. Also, found the time to be bad, it was running on two different cycles at the same time, shorted out and contacts welded.
Thanks for the input.
Pool Main breaker keeps tripping beckyreyes Electrical 12 08-11-2013 04:06 PM
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
Tripping Wrong Breaker woodworksnmore@comcast.ne Electrical 15 03-28-2008 01:47 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
HW tank breaker tripping arichard21 Electrical 6 10-31-2007 04:13 PM
