Kenmore Top Freezer Refrigerator Problem. - Appliances - DIY Chatroom Home Improvement Forum
Old 06-12-2011, 01:42 PM   #1
kenmore top freezer refrigerator problem.
I have a kenmore top freezer refrigerator. The freezer is working fine.
The refrigerator is cool but not cold by any means. I have cleaned the coils. There was frost on the back of the freezer so I unplugged it for
several hours....still not cold in refrigerator part. I was thinking it must
be the evaporator fan motor because there does not seem to be any
air flowing into the refrigerator part. However, one post describes
a similar problem and says it was the defrost thermostat. How do I determine which part I need? Thank you......
joanneh105 is offline   Reply With Quote
Old 06-12-2011, 01:50 PM   #2
the Musigician
DangerMouse's Avatar
I moved this to it's own new thread. You'll get better responses this way.
Did you read and try the things posted in the other thread?
The first thing I would check is the fan, be sure it's rotating full force.
DM
Old 06-13-2011, 07:57 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
frost build up on the freezer evap coils will cause this problem. You need to pull the cover off the back of the frezzer and see if it is built up, that way you can also verify if your evap fan motor is running also. By unplugging it for a few hours would not have been long enough to melt all the build up, and that would only be a temporary solution anyway.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 06-13-2011, 08:08 AM   #4
Rewards Points: 476
I belive you said you cleaned the coil's? You must have taken the back plate off from inside of the freezer? Was it froze solid? Did the little motor run?? that is what move's cold air down to the ref. part. If froze use a hair dryer. If the frezer is working and stuff is froze solid and hard than the motor must not be running ? good luck
del schisler is offline   Reply With Quote
Kenmore Freezer not freezing completely rich kahl Appliances 2 05-12-2011 09:14 PM
Kenmore 596 bottom freezer cold top warm klimshelf HVAC 2 03-30-2011 08:32 AM
Kenmore fridge stops cooling with frost in freezer donnoit Appliances 3 09-20-2010 07:59 AM
Kenmore fridge not cooling, freezer ok bobvanhalder Appliances 20 10-22-2008 11:36 PM
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-22-2008 10:52 PM
