Kenmore Side By Side Refrigerator Coldspoot Model 52582201 Not Cooling - Appliances - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 10:57 AM   #1
Kenmore side by side refrigerator coldspoot model 52582201 not cooling
Hi all.. please help me diagnose the problem..The fan below the fridge in the back side behind the freezer is running, The fan inside freezer above coils is running(evap fan?).. but no cold air.
There was no frost inside freezer... the compressor in the back is warm/hot but does not vibrate(is it suppose to?)
unplugged the unit for about 2 hrs...vacuum vents
Please help.. I'm tight on budget so if I can DIY with your help I'd really appreciate ...somewhat handy with tools... Thanks
jkay is offline   Reply With Quote
Old 06-01-2011, 12:13 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
so you really don't know if the compressor is running? if it is not running it could be a bad compressor relay or the compressor itself could be bad. If it is running then it could be low on refrigerant and/ or a bad compressor. Either way its not a good situation.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
tperkovich (03-17-2012)
Old 06-01-2011, 04:08 PM   #3
Replaced the compressor relay.. The old one was broken as it was rattling when shake and little ceramic pieces came out when opened. SO far looks like the cold air is coming in the freezer but it's only been 15 minutes or so since I plugged it back on.... fingers crossed... Just Hope the compressor didn't get damaged and relay was the only problem.
Old 03-17-2012, 08:03 PM   #4
Does anyone know where I can get the refrigerant or compressor for this model on a sunday?
tperkovich is offline   Reply With Quote
Frigidaire side by side model # FRS23W3AWE polpep Appliances 2 05-24-2010 06:28 AM
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 07:55 PM
Kenmore side by side refrigerator not cooling bidderbl Appliances 1 09-26-2009 06:48 PM
GE side by side refrigerator not cooling joedadog Appliances 2 01-15-2009 11:23 PM
Kenmore side by side filter is stuck HELP! cosmo254 Appliances 5 05-30-2008 10:24 PM
