Kenmore Series 90 Dryer Glow/No Flame - Appliances - DIY Chatroom Home Improvement Forum
Old 01-24-2015, 01:49 AM   #1
Rewards Points: 6
A little background just incase there may have been something triggering this.
I recently replaced my propane lines..tested for pressure and everything. Stove upstairs works fine. Dryer at first was getting very hot. I thought it may have been bc i went from 3/8 tubing to 1/2 but was informed that due to the lp regulator at the tank it's a non issue.
Then in a totally unrelated event the outlet i use for my washer dryer sparked and went on fire. I figured it was bc when the house was wired 50 years ago they didnt make a dedicated line for. It wound up being that plus the wires were just so old and brittle.
So i now have a dedicated circuit foe the washer dryer however now im getting no heat to the dryer. I know its not the propane bc it held in a pressure test, the stove works, i have a propane detector.
Im thinking of the dryer getting really hot when i connected my new lines so could it be the hi limit therm?
I was also thinking maybe the outlet problem caused the fuse to blow.
I am getting a glow from the igniter but no flame to follow. Would i even be getting a glow if it was a fuse problem?
I have no problem replacing parts step by step but I just wanted to try and get a better idea of what to replace.
Thank you for reading.
ozzlvlosis is online now   Reply With Quote
Kenmore 400 dryer Jay2013 Appliances 19 07-23-2013 09:22 PM
Kenmore Dryer Shuts Off Prematurely simeltzer Appliances 5 06-17-2013 06:53 PM
help !!!! Maytag dryer model LDG 410 no flame Gates Appliances 13 08-07-2012 08:48 AM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 11:35 AM
Whirlpool Imperial series gas dryer troubleshooting koz123 Appliances 12 09-20-2011 05:24 PM
