Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-15-2012, 06:38 PM   #1
Kenmore Series 800 cold when set on hot
Model 110.27831600 bought on 12/30/2007
When I set the water control knob to HOT, cold water comes out. When I set it on COLD, hot water comes out. Yes, the water lines are hooked up correctly, the washer has been working fine for 5 years now. Could my problem be the water valve? Automatic Tempature Cntrol Sensor? or something else?
What do you guys think?
D
StahlMaster is offline   Reply With Quote
Adding on to cold air return agicr HVAC 13 03-27-2011 02:33 PM
Freezing storage room next to the cold room Van3 Building & Construction 2 01-23-2011 06:50 PM
Cold Air timmy k HVAC 0 12-14-2010 07:26 PM
Water Heater - Water reversed, hot is cold, cold is hot acaciaavenue Plumbing 5 12-09-2009 12:00 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 11:29 AM
