Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-09-2010, 02:29 PM   #1
Kenmore s/by/s no water no ice
I found out on 7/29 that this unit-Kenmore M#253.56963602-was not making ice nor delivering water, and for quite some time now too!
On 8/19 I replaced the filter-part Ice JSI-2filter PN 218732315—9911 from Filters fast-#WF2CB Frig PS2 W. instantly had water at the door, 1 hour later still no ice. Thought it may need time.
On 9/7 was informed that there is still no ice and now the water quit again.
Any suggestions? Need help here!? These are really nice folks and $ are sparse.
thanks
RWCII is offline   Reply With Quote
Old 09-09-2010, 08:36 PM   #2
HVAC / Plumbing
thanks
I would make sure I'm getting water out of the filter. then, check water valve, Freezed temp.has to get around 8 deg. for ice maker thermostat to operate
kenmac is offline   Reply With Quote
Old 09-10-2010, 07:46 AM   #3
Post
Thanks Kenmac, how do I make sure water is getting out of the filter?
And the water valve you are referring to, is it the fill vale on the back of frig?
Thanks again!!!
Old 09-11-2010, 01:19 AM   #4
HVAC / Plumbing
Thanks again!!!
The water valve ( solenoid) will be where the incomming water line connects. Make sure when it cycles to fill the ice maker that water comes out. I have replaced several of these solenoids
The Following User Says Thank You to kenmac For This Useful Post:
RWCII (09-16-2010)
Old 09-11-2010, 10:29 PM   #5
long island, NY
(I'm not an expert... just a kenmore frige owner!)
what would happen if you just removed and re-inserted the filter? Do you get water again? Maybe there's something off near the filter connection?
Just wanted to let you know something that I noticed about our kenmore frige (which is too small for our needs)..... If there is some object pressing against the freezer door (becuase it's too close to the shelf edge), the door seal is not complete, although it appears to be fine... this subtle increase in temp is enough to prevent the ice from freezing, and ice production completely halts. After we eat enough out of the freezer and the object shifte back, ice production returns again. (We have the temp set to the manufacturer's recommended settings). So, these ice makers are really compromised by subtle changes in door position.
diy'er on LI is offline   Reply With Quote
The Following User Says Thank You to diy'er on LI For This Useful Post:
RWCII (09-16-2010)
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
water borehole question joeuser General Discussion 2 04-18-2010 11:33 PM
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 08:55 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
