Kenmore Refrigerator Model Number 75502. - Appliances - DIY Chatroom Home Improvement Forum
Old 08-05-2012, 07:03 PM   #1
kenmore refrigerator model number 75502.
the freezer is working fine. but the refer is not getting cold. I had the unit in storage and then put in the garage it worked for about two weeks then it quit cooling
sharmon is offline   Reply With Quote
Old 08-05-2012, 07:18 PM   #2
Rewards Points: 14,312
Check the cirulating fan at the back of the fridge.
Just open the door a few min. and it you should be able to hear it running.
sharmon (08-05-2012)
Old 08-05-2012, 07:27 PM   #3
the fan is running but its not moving air up o the vent for the fridge
Old 08-05-2012, 09:49 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
sounds like a defrost problem, check for frost build up on the back wall of freezer
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 09-19-2012, 11:21 PM   #5
Question
We have the same model and problem and cannot hear any fan at all. Fridge hot. Freezer cold. Got the back open in the freezer and there is the fan...NOT working. So maybe we need a new fan or motor or both?
Ordered this motor. It has the same bracket.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=160871464673
Part# ER 12002744 Refrigerator Evaporator Freezer Fan Motor
seraphima is offline   Reply With Quote
Old 09-25-2012, 07:40 AM   #6
custom user
Rewards Points: 150
Could be that the fan blades are hitting ice, therefore not turning. If so, the defrost relay is a likely culprit. I found a bad one yesterday, it was mounted on the coil and busted apart. You need to melt some ice to see it if it is frozen over.
JasperST is offline   Reply With Quote
Trane XL80 blower motor part number? keverino HVAC 17 01-10-2012 09:01 AM
D 3 number 12 wires equal one number 8 wire? Uncle Wayne Electrical 3 01-26-2011 08:00 PM
How much does it cost to operate my Kenmore freezer? sofasurfer Appliances 2 01-25-2011 12:46 PM
Carrier Gas pack Model number peakslayer HVAC 0 01-10-2011 11:02 AM
Lid Switch for Kenmore washer Steve76 Appliances 6 01-04-2008 12:44 PM
