Kenmore Refridgerator Blower Fan - Appliances - DIY Chatroom Home Improvement Forum
Old 08-23-2012, 04:58 PM   #1
kenmore refridgerator blower fan
I have a side by side kenmore fridge , the blower fan in the freezer compartment does not kick on to blow cold air to the other side, i replaced the fan motor (it was bad) and also replaced the defrost timer, what else can be keeping the fan from kicking on, it did run for a few minutes but then stopped, than k you
CRSHOAF is offline   Reply With Quote
Old 08-23-2012, 06:07 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,584
need model # to correctly identify who built it for Sears before answer can be given
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 08-23-2012, 09:57 PM   #3
30 year tech
hvac122's Avatar
May be the door switch.
Its A Good Life!
hvac122 is offline   Reply With Quote
Old 08-26-2012, 04:09 PM   #4
Bombastic Idiot
notmrjohn's Avatar
What was 'bad' about the old motor? Could be the same thing happened to new one,some kind of power surge or obstruction is making it burn out. If you're sure it was bad, no loose or corroded connection anywhere.
notmrjohn is offline   Reply With Quote
kenmore water softener Squiddly Plumbing 6 11-16-2011 08:51 AM
Bradford White or Kenmore HWH? Durt Ferguson Plumbing 0 03-07-2011 02:54 PM
How much does it cost to operate my Kenmore freezer? sofasurfer Appliances 2 01-25-2011 01:46 PM
Kenmore Icemaker install Turnerg110 Appliances 2 07-21-2008 04:55 PM
Kenmore Dishwasher HELP!! eric-c Appliances 2 06-25-2008 06:07 PM
