-   -   kenmore refridgerator blower fan (http://www.diychatroom.com/f47/kenmore-refridgerator-blower-fan-154614/)
CRSHOAF 08-23-2012 04:58 PM
I have a side by side kenmore fridge , the blower fan in the freezer compartment does not kick on to blow cold air to the other side, i replaced the fan motor (it was bad) and also replaced the defrost timer, what else can be keeping the fan from kicking on, it did run for a few minutes but then stopped, than k you
hardwareman 08-23-2012 06:07 PM
need model # to correctly identify who built it for Sears before answer can be given
hvac122 08-23-2012 09:57 PM
May be the door switch.
Its A Good Life!
notmrjohn 08-26-2012 04:09 PM
What was 'bad' about the old motor? Could be the same thing happened to new one,some kind of power surge or obstruction is making it burn out. If you're sure it was bad, no loose or corroded connection anywhere.
