Kenmore Range - 95024 - Broiler Element Will Not Turn Off - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 01:33 PM   #16
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
SEARS CARES= oxymoron
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 10-17-2015, 12:17 PM   #17
Rewards Points: 2
Latecomer to thread about Kenmore broiler issues
All, while this is an old thread, the topic is still current. I definitely see the validity in trying to repair things- especially appliances. I've done a lot of that- replacing motors in electric drills, or the drum assembly in a front-load clothes washer (the overhung load on the shaft puts a significant load on the shaft bearings, causing failure far before what I consider to be a reasonable service life). I have a Kenmore oven/range unit- the model number isn't really important because the relay in question (relay that is soldered to circuit board and switches power to oven element) appears to be used in many models. In our case, the relay didn't fuse (or "stick"). One of the soldered terminals where the relay connects to the control board melted. I went on an internet search to see what experiences my fellow consumers were reporting, and found that many others had the same relay with the exact same terminal melting. There's even an online video showing how to resolder the terminal. I went ahead and resoldered it but kept thinking about the cause, and whether it was really a safe fix that would properly resolve the issue. With a lot of thinking and a little more internet research, I've concluded the fault is in the design of the circuit board (my own opinion, I'm not an expert, and am trying to keep an open mind- but I'm concerned enough that I filed a complaint with the Consumer Product Safety Commission). It appears there's a relay on the control board that either fuses the contacts, locking the broiler element on, or builds up enough resistance across the contacts to generate sufficient heat in the relay terminal to melt the solder joint. Resoldering the joint, replacing the relay, or even replacing the control board with a new unit, seems to leave open the risk of a future control failure that could lock on the broiler element. By the way, it appears to me a fused relay contact results in an overheating circuit with no overtemperature safety device. Given the integrated nature of the circuit board, it seems that a resolution for the existing models in all of our kitchens would be prohibitively expensive, and it is unlikely Sears and other manufacturers/retailers of appliances with this relay design will voluntarily address the issue. Seems like the best way to address the issue is for anyone concerned/willing to file a complaint with CPSC and request an independent government investigation. No one wants to hear this type of news (I don't expect any of the happy/grateful responses to the video showing how to fix your stove with a solder joint and save hundreds of dollars), but it is simply the truth as I see it- and it might help avoid a tragic event.
JoeK1900 is offline   Reply With Quote
Old 03-23-2016, 06:05 PM   #18
Rewards Points: 2
Re: Kenmore Range - 95024 - Broiler element will not turn off
I have a 95002. It spontaneously went into overdrive last night. Charred a few items on nearby counters (not on the range). The breaker tripped otherwise we would have had a major issue in the kitchen. I filed with the CPSC. I intend to do no more business with Sears in the future.
MrBob is offline   Reply With Quote
Old gas kenmore range....no oven, but burners work shadango Appliances 24 11-17-2010 07:45 AM
When I turn on my hob, one or two element sparking mpj111 Appliances 0 07-31-2010 09:34 PM
Kenmore Range Kajunkind Appliances 0 02-24-2010 09:44 PM
DCS range help mazzonetv Appliances 0 07-28-2009 08:09 PM
Kenmore Wall Oven doesn't turn on queen614621 Appliances 1 12-15-2008 05:45 PM
