Kenmore Range - 95024 - Broiler Element Will Not Turn Off - Appliances - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 07:44 PM   #1
Kenmore Range - 95024 - Broiler element will not turn off
I was cooking dinner today and turned on the broiler and when I was done I pushed the off button. A short while later I noticed a burning smell and looked at the electronic display and only the time was displaying as if everything was turned off. The smell got worse so I opened the oven door and saw the broiler element bright red even though it was off. So I turned off the breaker for 15 minutes and when I turned the breaker back on it came on again without an indication from the electronic control panel. I tried pusing buttons like bake and broil and off again but it wouldn't go off.
Any ideas on how to repair? Can I just remeove the Broiler element and it still work for all other functions?
Thanks,
tkolarik is offline   Reply With Quote
Old 08-22-2011, 08:38 PM   #2
Rewards Points: 6,652
You could repair it, but due to this range has had issues of the Broiler committing Harri Kari, I would just replace it, due to the fact, that this is not the only Kenmore range that has caught fire, due to the Broiler element. And as for removing the element, look at it this way. Do you want to risk your and your family's lives, along with your home, due to this risk. Here is what Lowe's has on their site for Electric ranges http://www.lowes.com/pl_Electric+Ran...sales_dollar|1
The ratings on Electric ranges:
http://www.consumersearch.com/ranges-reviews
Just pick your poison.
Old 08-22-2011, 09:53 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
Originally Posted by gregzoll View Post
You could repair it, but due to this range has had issues of the Broiler committing Harri Kari, I would just replace it, due to the fact, that this is not the only Kenmore range that has caught fire, due to the Broiler elemen.
not sure how you came up with this opinion, since the op has not given a complete model# and therefore you really have no way of knowing, in fact you have no way of even knowing who manufactured this range for Sears.
what has happened is your broil relay has stuck. You will have to replace the entire elctronic control but it would sure be cheaper than a new range.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 08-22-2011, 10:36 PM   #4
The fact, that if you do a recall search on Kenmore stoves, there is the Elite that have done this, and as for that model number, it is 66595024100 or 66595024101. Personally, if my stove caught fire in the oven, I would replace it with a new unit, due to not wanting to take the risk of other problems. This is a widespread known problem with kenmore stoves, from what I found doing a websearch. If I was the OP, I would contact Sears and let them know that it caught on fire, and see if they will either fix it, or allow credit towards a newer stove to replace that one, and report to cpsc.gov.
Old 08-22-2011, 10:52 PM   #5
#1 HAWKEYE FAN
they never said it caught fire.
Old 08-22-2011, 11:08 PM   #6
It does not matter whether they stated that it did or did not. They stated that it was glowing bright red, and shorted out, even though the oven was off. It is the same behaviors as those units that have been recalled due to the broiler element going into meltdown, without the stove being on. That means that it is not safe, and just replacing the element would not be good enough, because there could be another underlying problem somewhere else on the unit. The safest way is to replace the unit with a brand new stove, and let Sears & report to cpsc.gov that they had this incident.
I have one of the Whirlpool portable dishwashers that had a recall just recently, because of the heating element. Instead of playing with fate, I chose to report my dw, so that I could have the element replaced, even though it did not show any signs of going into meltdown.
Old 08-22-2011, 11:16 PM   #7
#1 HAWKEYE FAN
[quote=gregzoll;713262] That means that it is not safe, and just replacing the element would not be good enough, because there could be another underlying problem somewhere else on the unit. [/quote
thats exactly right and that is why I told them they must replace the control board because of a stuck broil relay. Simple fix for about $200.00
Old 08-23-2011, 01:15 AM   #8
I believe the entire unit is a 665.95024104 being a bisque color unit. I think it was manufactured by Whirlpool. It didn't catch fire but it gave off a burning smell that it didnt even when it was running clean cycle.
I bought it 10 years ago when my son was born because the existing unit was not "child-safe". So I guess then the question is $200 to fix a 10-year old unit or replace it at $700.
Old 08-23-2011, 01:58 AM   #9
The broiler part and the new circuit board together are around $300, if you buy through either Sears Part Direct, or Repairclinic.com, then you have to figure in labor to have it installed. It is really up to you. Stainless is in, so are those stoves with pie ovens in them. Look around, due to you may be able to get a scratch & dent at a cheaper price. I have a Whirlpool gas and replaced the circuit board on it a couple of years back, and it really is not hard. Now I have to replace the spark igniter, which I am calling one of the local places to do it, because I am unable to lean forward right now, otherwise I would do it on my own. As for the broiler element, you have to be in the oven to pull the old and put in the new, which is also not hard.
Just pick your poison. Do you want to spend $300 for both parts and install yourself, or get a newer unit, due to this one is ten years old. Keep in mind, there is always Murphy lurking around the corner, and he tends to bring his family with him.
Old 08-23-2011, 07:47 AM   #10
Geez! i don't understand the mind set anymore. people saying Oh, it's ten yrs old or 8 or 7-whatever, i'll just replace it! guess it started with our Asian friends importing throw away TV'/mo etc. if a $700 oven, $500 washer or a $1000 refrig etc is in good condition, has the features one uses and been working ok-why trash it? expected future problems? plenty of problems with new stuff, and the level of warranty/contract is absymal anymore. since i'm in the 'BIZ' i'm partial to fixing but with that said; especialy with a competent DIY', age of the appl shouldn't be the determing factor.
Jacques is offline   Reply With Quote
The Following User Says Thank You to Jacques For This Useful Post:
hardwareman (08-23-2011)
Old 08-24-2011, 01:28 PM   #11
Well, thanks to you folks for suggestions. I went to the CPSC.gov website and found that there were a few similar units from Whirlpools with the same problem. So I got mad and called Customer Service which actually offered to pay for the part (I would have to handle install fee) so I told them I didn't want to replace a part with one that potentially had the same problem and could burn down the house or take a life. So they offered me $150 since I have bought like 12 appliances over 20 years through them. I asked if they would pay for delivery which is $70 but they said no.
At that point I went on line and got the name and office phone number to the president of Sears Kenmore and called his office and spoke to an administrative assistant of his. At this point the ball is in their corner. Seeing how I spent about $6000 or $7000 in DOCUMENTED purchases with them, the $150 is not appropriate especially since the unit is only through half of its expected lifespan. The $150 offer will not be enough to keep me as a customer anymore! Besides, it is a defect of a Whirlpool unit and Sears continues to use them as a vendor. Any concession they award to me can easily be recovered from.
Going now to post a complaint with the Consumer Public Safety Commission!
Old 08-25-2011, 12:56 PM   #12
Sears Cares
Dear tkolarik,
My name is Laura with Sears Cares; I found your post here and I want to apologize for all the difficulty you’ve had in getting your range repaired. When something we rely on fails it can be extremely frustrating, especially after finding out that this has happened to others. I can certainly understand your reluctance to pay to have part installed and your concerns with keeping the unit in your home based on your research. From your post I see that you were offered $150 towards a new purchase and have reached out to our executive office for assistance with this issue. If you need any additional help, we at Sears Cares would be happy to work with you towards a resolution. At your convenience please contact our office via email at smsupport@searshc.com and a personal case manager will contact you directly to discuss this experience. In the email, please provide a contact phone number, the phone number the range was purchased under (if different than the contact phone number), and please do include your user name (tkolarik) for reference to your issue. Again, we are very sorry for any inconvenience and please let us know if we can be of any assistance.
Thank you,
Laura D.
Social Media Moderator
Sears Social Media Support
SearsCares is offline   Reply With Quote
Old 08-26-2011, 09:51 AM   #13
So there ya go-Sears Cares. let us know the outcome. i would opt for the free part. a new one is going to have the same set up-electronicaly controled bake/broil relays. why spend the extra money? if there was a problem with this control [after 10 yrs?] it would have been respec' out. so should be fine. i'm no appolgist for Sears but they're a retailer, why get cranky with them?
Old 08-26-2011, 11:00 AM   #14
Sears "say" they care, they haven't shown it yet!
But I am definately not replacing the part with another that could do the same thing. I have my family and a lifetime of photos, records, mementos and other things thart are not replaceable. I don't want an appliance whose function in life is to make heat, and who has proven itself not follow my instructions, living in my home.
If I take a big hit on this financially, I'll get my "pound of flesh" as they say!
Old 08-26-2011, 11:05 AM   #15
I had to replace the circuit board on my gas stove, and had no qualms in doing so. If Sears is honoring their warranty to replace the part, regardless of the age, let them do it. Otherwise, as they have told you, they will give you xx amount towards a new purchase. It is your choice, and no one is forcing you which to take.
I would say that this thread has ran its course, and there really is not much more we can do to help.
Old gas kenmore range....no oven, but burners work shadango Appliances 24 11-17-2010 07:45 AM
When I turn on my hob, one or two element sparking mpj111 Appliances 0 07-31-2010 09:34 PM
Kenmore Range Kajunkind Appliances 0 02-24-2010 09:44 PM
DCS range help mazzonetv Appliances 0 07-28-2009 08:09 PM
Kenmore Wall Oven doesn't turn on queen614621 Appliances 1 12-15-2008 05:45 PM
