Kenmore Oven Broiler Stuck On - Appliances - DIY Chatroom Home Improvement Forum
Old 01-19-2013, 07:21 AM   #1
Rewards Points: 77
I have a kenmore 790.95680302 electric range. Yesterday I went to bake dinner at 350 deg when I found 20 minutes later the broiler element was on high, and the oven was over 700 deg.
I tried disconnecting the wires to the broiler element, taping them, to see if the oven would heat. It did not. So the bake element isn't working at all either.
What might the diagnostic steps be to track down the faulty part? I have the wiring diagram but are unsure what to test, or do I just replace the electronic oven control?
daveplot is offline   Reply With Quote
Old 01-19-2013, 10:59 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 184
I am by no means a repairmen, I just barely stumble through some repairs, but to me it seems the contacts in the controls are stuck shut, my guess would be replace the controls.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-19-2013, 11:09 AM   #3
Rewards Points: 13,256
http://www.repairclinic.com/RepairHe...roubleshooting
Old 01-19-2013, 04:23 PM   #4
Rewards Points: 77
Thanks, ordered control board. Elements tested fine.
The Following User Says Thank You to daveplot For This Useful Post:
BigJim (01-19-2013)
Old 01-19-2013, 07:15 PM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
relay on the oven control board is sticking
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
oven stuck in broil gcan Appliances 2 12-30-2012 11:42 PM
Kenmore Oven Broiler Kaput...need top fix downdraft Appliances 11 06-17-2012 12:11 AM
Kenmore Oven Element Arcing Valerie1960 Appliances 2 01-30-2012 09:03 AM
Old gas kenmore range....no oven, but burners work shadango Appliances 24 11-17-2010 07:45 AM
Kenmore Wall Oven doesn't turn on queen614621 Appliances 1 12-15-2008 05:45 PM
