Kenmore Model 110 Washer Motor Coupler Failure - Appliances - DIY Chatroom Home Improvement Forum
Old 01-13-2014, 08:33 AM   #1
Rewards Points: 1,628
Kenmore model 110 washer motor coupler failure
I have a Kenmore model 110.16502690 top load washer that's been pretty reliable over the years.
About a month ago it stopped working, basket won't spin but I could hear the motor turning. After taking it apart it was the motor coupling that broke. The "black rubber wheel" in the middle of that sandwich cracked and broke off.
I looked up a nearby appliance parts store and went over to get a replacement. I asked for a genuine OEM replacement but they gave me something that looked a little different. They said this is the genuine replacement part and that's all that's available, and I did search online as well and that seems to be all that's available as well.
I did see some "versions" of this part, there is another version where the white couplers on either sides with a metal sleeve, but I also saw a few web sites stating this is a bad design because if it's going to fail, they prefer the coupler to fail instead of a much more expensive part, makes sense.
The part I got from this appliance store says "285753" and the brand name is "Jason".
Now a month later, I have the same failure. The middle piece cracked, so did one of the white couplers.
Now I am wondering...why it failed? Is it:
#1: The part I got is generic, inferior and just doesn't last long. If so where can I get reliable genuine OEM parts?
#2: Just a coincidence, may be an extra heavy load of laundry and things weren't balanced and this happened, in which case I would go get another "Jason" part 285753.
#3: An indication something else is not aligned which caused stress to the motor coupling, which broke it the first time and now the second time. I need to diagnose somewhere else to trace the source of the real problem, or else I would be replacing motor couplings every few weeks. If that's the case, where should I look?
Thanks in advance for any advice.
miamicuse is offline   Reply With Quote
Old 01-15-2014, 09:30 PM   #2
Rewards Points: 77
I would suspect a defective part. Go and claim warranty on the old one at the location where you purchased it. Also, I would order another brand online i.e FSP or similar in case that one fails too.
I wouldn't start chasing down another problem without first ruling out a possible defective part.
mlijoi is offline   Reply With Quote
GE Profile Washer Model WPRE6100G0WT neither agitates nor spins tammy2006 Appliances 5 02-13-2010 01:33 PM
My GE Washer Model #WJXR2080T8WW Will not Spin TDM Appliances 2 01-17-2009 08:56 PM
Kenmore washer won't drain. razburn Appliances 1 11-30-2008 08:25 PM
Ge Washer Model # Gf900483g Help Help Help WOW12344 Appliances 1 04-16-2008 09:51 PM
Lid Switch for Kenmore washer Steve76 Appliances 6 01-04-2008 12:44 PM
