Kenmore Ice Maker - Appliances - DIY Chatroom Home Improvement Forum
Old 03-17-2009, 06:03 PM   #1
Kenmore Ice Maker
I have a Kenmore refrigerator freezer with an icemaker that is several years old. The ice will dump now but its still connected. It will dump out the whole tray and the ice doesn't break apart. Any Idea's would be appreciated. Thanks in advance. Hart.
Hart is offline   Reply With Quote
Old 03-17-2009, 07:49 PM   #2
HVAC / Plumbing
are you saying that the ice cubes won't fall/ break apart after the ice falls into the tray ???
kenmac is offline   Reply With Quote
Old 03-17-2009, 09:38 PM   #3
Yes. The tray will fill with water and the ice cubes will freeze and dump in the bin but the cubes remain connected for whatever reason. It's almost like the water valve may be letting a little to much water into the freezing chamber if this makes sense? The cubes don't break apart in the bin when they are dumped. Then they can't be dispensed because they are to large. Hope this makes sense.
Old 03-17-2009, 10:23 PM   #4
HVAC / Plumbing
do you have the selector that you can change the size of the cubes. ? If so change to the smaller cubes & see if it does the same
Old 03-18-2009, 04:54 PM   #5
No I don't have the selector size switch on our ice maker.
Kenmore (Whirlpool) refrig ice maker problem lexort Appliances 18 05-07-2016 09:28 AM
Kenmore Ice Maker - Electrical Questions BobNewOrleans Appliances 13 07-05-2009 01:39 PM
Kenmore fridge - Ice Maker issue mustangcobra44 Appliances 11 01-28-2009 09:05 AM
Kenmore ice maker acting strange BJLower Appliances 3 10-24-2008 11:14 PM
