Kenmore Gas Oven Won't Pre-Heat (weak Btu Output) - Appliances - DIY Chatroom Home Improvement Forum
Old 07-13-2013, 04:10 PM   #1
Rewards Points: 392
Kenmore Gas Oven Won't Pre-Heat (weak btu output)
I have a 1996 Kenmore Oven 362.72491990
It has a hot surface ignition and gas valve. There are two outputs on the gas valve, one for the broil and one for the oven. The oven is getting weak and can't pre-heat anymore. The valve runs on 3V AC or so and is connected in series with the ignitor.
Based on my testing so far, what happens is the ignitor comes on and the gas comes on and it looks like all is well but then the gas cuts back and gets really weak and the oven never gets very hot.
I measured the voltage on the valve and it is only 2.5V. I measured the voltage on the other valve that is use for the upper burner (Broil) and it is a good 3.5v so either my hot surface ignition is getting really weak and creating too much resistance to give the gas valve enough to stay open. The other possibility is that the controller board is getting weak and can't provide enough juice to keep both the ignitor and the valve happy. I'm guessing that I just need a new hot surface ignitor.. Thoughts?
zootjeff is offline   Reply With Quote
Old 07-14-2013, 08:54 AM   #2
Rewards Points: 1,300
My recollection on these is that the board monitors the amount of current the igniter uses. If it is not in the range it expects to see then it won't open the gas valve. I had to replace one (igniter) on mine because of this. It would glow but not lite.
danpik is offline   Reply With Quote
Old 07-15-2013, 04:19 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
sounds like a weak ignitor to me
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Help fixing Kenmore oven jackpine Appliances 3 03-25-2013 09:43 PM
Kenmore Oven broiler stuck on daveplot Appliances 4 01-19-2013 06:15 PM
Intermittent heat Kenmore Dryer Mr.Pappy Appliances 2 02-19-2010 03:18 PM
