Kenmore Gas Dryer Not Heating - Appliances - DIY Chatroom Home Improvement Forum
Old 07-04-2010, 08:34 PM   #1
Arrow
kenmore gas dryer not heating
Model no. 72832100
natural gas dryer.
problem:
not drying clothes enough or not at all, just air drying.
troubleshjooting so far:
took back panel off and vaccumed area.
tested thermal fuse- test ok
took out vent duct and cleaned inside- yes it was full of lint after 10 years.
restarted unit and heater came on the first heat cycle. afterwards, only the igniter, no flame.
took off front panel and looked at photovoltic cell, appears clean, no visual signs of trouble in this area (heated wires, burnt parts etc.)
about 5 years ago I had the thermostat replaced. I believe it could be the same problem. I can get the part locally and install myself, but would like any other testing steps before doing so.
any help would be appreciated.
gdbudd is offline   Reply With Quote
Old 07-07-2010, 07:54 PM   #2
update:
replaced the operating thermostat and have the same results. The dryer works fine when I have it apart. That is it sounds like a switch closes, then a few seconds later the ignitor comes on, then the gas lites. It did this fine for about 20 minutes. Then I put the front panel back on and the gas lit once and that was it.
i also notice a buzzing or humming noise. Possibly the coils for the gas valve are giving out after getting warm???
Old 07-10-2010, 08:22 AM   #3
The problem has been fixed. turns out it was the gas burner and pilot valve coils. you can buy both in a kit for about $46.00
Noisy Kenmore Dryer Skeeter01a Appliances 2 02-22-2010 07:05 PM
Intermittent heat Kenmore Dryer Mr.Pappy Appliances 2 02-19-2010 03:18 PM
Kenmore Dryer Problem ElectricianJeff Appliances 1 02-23-2009 06:33 AM
HELP ! trouble putting belt back on Kenmore elec. dryer ! jays_gyrl1027 Appliances 2 09-17-2008 06:16 PM
electric dryer heating element gooch Appliances 2 03-27-2007 09:31 PM
