Kenmore Gas Dryer Not Heating - Appliances - DIY Chatroom Home Improvement Forum
Old 04-30-2012, 02:28 PM   #1
wilderstyle
Kenmore Gas Dryer not heating
Can someone walk me through fixing this? I checked some posts but they were beyond square one.
wilderstyle is offline   Reply With Quote
Old 04-30-2012, 09:02 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
do you have an ohmmeter? if you do I'd be happy to help.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-02-2012, 06:58 AM   #3
Rewards Points: 1,294
does the drum turn?
danpik is offline   Reply With Quote
Old 05-03-2012, 09:28 AM   #4
wilderstyle
Yes, drum turns and I bought an analog multimeter.
Old 05-03-2012, 05:47 PM   #5
#1 HAWKEYE FAN
first thing you have to do is get access to the burner assy, either by removing the entire front panel or the access panel below the door depending on your model. Your problem is most likely the igniter, so unhook it and ohm it. If it is bad then replace it, if it is good then look and the thermal fuse and ohm it. 95% chance it is one of those 2 items.
Old 05-04-2012, 08:56 AM   #6
wilderstyle
I did it! It was the thermal fuse. I checked parts on line looking for a fuse kit I read about on the internet. Sears parts showed this part as the most ordered, only 15 bucks, so I gave that a shot. Totally worked! Thanks for answering my post. I am a Nana and had to break a few time to watch my grands, but I did it!
Old 05-04-2012, 07:56 PM   #7
#1 HAWKEYE FAN
good for you, now you must investigate a little further. thermal fuses usually blow for a reason. check the exhasut venting and the hood out side.
The Following User Says Thank You to hardwareman For This Useful Post:
Tom Struble (05-04-2012)
Old 05-05-2012, 02:24 PM   #8
wilderstyle
Would it blow if my vent is not attached right or is too close to the wall? I have a raised house, I think it vents under. I checked the hose, it wasn't blocked.
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 10:35 AM
kenmore gas dryer not heating gdbudd Appliances 2 07-10-2010 08:22 AM
Noisy Kenmore Dryer Skeeter01a Appliances 2 02-22-2010 07:05 PM
electric dryer heating element gooch Appliances 2 03-27-2007 09:31 PM
