Kenmore Fridge Warm, While Freezer Is Cold - Appliances - DIY Chatroom Home Improvement Forum
Old 07-02-2013, 04:28 PM   #1
Post
Kenmore Fridge warm, while freezer is cold
This is in addition to the following thread:
Fridge not cooling - evap fan?
I encountered the problem with my Kenmore Coldspot fridge where the fridge is much warmer than the icebox. I have removed the back paneling inside the freezer, there is not much frost build up on the coils, I cleared the ice blockage from the pathway. The fan is not turning, but rotates freely using my finger. I was placing my fingers in behind and I touched the motor and received a little shock (note should of unplugged the fridge). So I'm guessing the fan motor is the issue? Please tell me I'm right! I guess I don't need a voltmeter find a voltmeter to determine if the fan is receiving power.
mcv709 is offline   Reply With Quote
Old 07-02-2013, 04:50 PM   #2
Rewards Points: 14,306
If the fans not running then the fridge will not cool down.
Got a model #?
Old 07-02-2013, 05:12 PM   #3
An old Tradesmen
Rewards Points: 8,178
Moved to Appliance forum.
The Following User Says Thank You to beenthere For This Useful Post:
mcv709 (07-03-2013)
Old 07-02-2013, 09:48 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
sounds like you have a bad motor but doing a voltage test would certainly tell you for sure.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 07-03-2013, 12:36 AM   #5
Got a model #?
Model number is a Kenmore Coldspot 106.XXXXXXXX. I read that only the 106 matters somewhere on another site. I was planning on contacting Sears for the replacement part. I got a loan of a volt meter to confirm my speculation and i have unplugged the fridge for the night before i go any further.
Glad I got a basement clunker which still keeps the food in check.
Tags
broken fan , freezer cold , fridge warm , kenmore
Fridge Too Warm Then Too Cold - Help! marcus118 Appliances 3 06-27-2013 02:01 PM
Use freezer as fridge fjacky Appliances 10 03-14-2013 05:08 AM
Frigidaire 12 c/f fridge not working Freezer works IDIMyself Appliances 2 09-12-2012 05:08 PM
Kenmore 596 bottom freezer cold top warm klimshelf HVAC 2 03-30-2011 08:32 AM
looking for 3/4 freezer 1/4 fridge rsplash40 Appliances 2 08-02-2010 10:01 AM
